<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Flash new firmware to Faces Encoder]]></title><description><![CDATA[<p dir="auto">Hey,<br />
I am using the faces encoder in a project and the I’d like to disable the led ring feedback when you click the encoder. I found the firmware of the encoder on <a href="https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Module/ENCODER/firmware_328p/FacesEncoder328" target="_blank" rel="noopener noreferrer nofollow ugc">github</a> so there must be a way to flash new code to it.<br />
Do I use the pin header on the inside and an Arduino as an ISP?<br />
Could you provide some more information on the process please?</p>
<p dir="auto">Cheers.</p>
]]></description><link>https://community.m5stack.com/topic/2638/flash-new-firmware-to-faces-encoder</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 11:26:38 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2638.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Dec 2020 07:32:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Flash new firmware to Faces Encoder on Tue, 22 Dec 2020 09:43:18 GMT]]></title><description><![CDATA[<p dir="auto">It's probably those 6 holes underneath the Atmega. See <a href="https://docs.m5stack.com/#/en/module/encoder?id=pinmap" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/module/encoder?id=pinmap</a></p>
]]></description><link>https://community.m5stack.com/post/11342</link><guid isPermaLink="true">https://community.m5stack.com/post/11342</guid><dc:creator><![CDATA[sodoku]]></dc:creator><pubDate>Tue, 22 Dec 2020 09:43:18 GMT</pubDate></item></channel></rss>
