<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AWS Edukit as normal Core2 for  Uiflow]]></title><description><![CDATA[<p dir="auto">Hello ,<br />
I have a question</p>
<p dir="auto">Is it possible to flash AWS Edukit for usage of uiflow latest version as a normal Core2?</p>
<p dir="auto">Or more simple way,</p>
<p dir="auto">Can I use AWS Udukit as a normal Core2 then again as AWS Edukit eith a flash possibility?</p>
<p dir="auto">If yes</p>
<p dir="auto">What shall I do?</p>
<p dir="auto">If no</p>
<p dir="auto">Is it possible in the future?</p>
<p dir="auto">Thank you in advance</p>
]]></description><link>https://community.m5stack.com/topic/2660/aws-edukit-as-normal-core2-for-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 22:01:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2660.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Dec 2020 07:17:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AWS Edukit as normal Core2 for  Uiflow on Thu, 24 Feb 2022 01:44:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stanely" aria-label="Profile: stanely">@<bdi>stanely</bdi></a> You are my hero - thanks for figuring this out!</p>
]]></description><link>https://community.m5stack.com/post/16750</link><guid isPermaLink="true">https://community.m5stack.com/post/16750</guid><dc:creator><![CDATA[greenleaf]]></dc:creator><pubDate>Thu, 24 Feb 2022 01:44:05 GMT</pubDate></item><item><title><![CDATA[Reply to AWS Edukit as normal Core2 for  Uiflow on Fri, 25 Jun 2021 12:52:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stanely" aria-label="Profile: stanely">@<bdi>stanely</bdi></a> could you explain the process little brief, becs im a new to this... and i want to control the RGB s in arduino ide... Is it possible... Help me..</p>
]]></description><link>https://community.m5stack.com/post/14244</link><guid isPermaLink="true">https://community.m5stack.com/post/14244</guid><dc:creator><![CDATA[pradeep]]></dc:creator><pubDate>Fri, 25 Jun 2021 12:52:01 GMT</pubDate></item><item><title><![CDATA[Reply to AWS Edukit as normal Core2 for  Uiflow on Sun, 11 Apr 2021 00:47:04 GMT]]></title><description><![CDATA[<p dir="auto">I figured out how to work the Core2 for AWS LED strips.  Add a custom RGB LED Unit with custom port.  SDA/TX is on 25, and SCL/RX on 22.  The Number of LEDs is 10.  Then set the neopixel device as you want it.  LEDs 1-5 are the right side, and 6-10 are left.</p>
<p dir="auto">Remember to also Enable the bus power mode.</p>
]]></description><link>https://community.m5stack.com/post/13470</link><guid isPermaLink="true">https://community.m5stack.com/post/13470</guid><dc:creator><![CDATA[stanely]]></dc:creator><pubDate>Sun, 11 Apr 2021 00:47:04 GMT</pubDate></item><item><title><![CDATA[Reply to AWS Edukit as normal Core2 for  Uiflow on Sat, 10 Apr 2021 23:31:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bricoms" aria-label="Profile: bricoms">@<bdi>bricoms</bdi></a>, Can you please expand on how you got the RGB left/right bars working on the AWS with UiFlow?  I'm using V1.7.14, enabled power, varied brightness, changed colors, and still black as night.  Thanks</p>
]]></description><link>https://community.m5stack.com/post/13469</link><guid isPermaLink="true">https://community.m5stack.com/post/13469</guid><dc:creator><![CDATA[stanely]]></dc:creator><pubDate>Sat, 10 Apr 2021 23:31:31 GMT</pubDate></item><item><title><![CDATA[Reply to AWS Edukit as normal Core2 for  Uiflow on Wed, 24 Feb 2021 20:34:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi! I flashed mine with uiflow and then micropython, all worked.<br />
Core2 for AWS is just a normal Core2 but wth the base for AWS that also works perfectly with uiflow. I can control the leds and everything. the only difference with the other Core2 is the color and the base for AWS witch has a secure "element" that you can use or not use.</p>
]]></description><link>https://community.m5stack.com/post/12653</link><guid isPermaLink="true">https://community.m5stack.com/post/12653</guid><dc:creator><![CDATA[BricoMS]]></dc:creator><pubDate>Wed, 24 Feb 2021 20:34:17 GMT</pubDate></item><item><title><![CDATA[Reply to AWS Edukit as normal Core2 for  Uiflow on Thu, 31 Dec 2020 01:18:02 GMT]]></title><description><![CDATA[<p dir="auto">Yes, you can flash your AWS Edukit M5 Core 2 with UIFlow_Core2.  I just did mine today and it works great with UIFlow.  Within a few minutes I had a useful app running on the device.</p>
<p dir="auto">You will lose access to the LEDs and the microphone as those are not supported (yet?) in the UIflow:</p>
<p dir="auto"><a href="https://github.com/m5stack/UIFlow-Code/wiki/Advanced" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/UIFlow-Code/wiki/Advanced</a></p>
]]></description><link>https://community.m5stack.com/post/11471</link><guid isPermaLink="true">https://community.m5stack.com/post/11471</guid><dc:creator><![CDATA[greenleaf]]></dc:creator><pubDate>Thu, 31 Dec 2020 01:18:02 GMT</pubDate></item><item><title><![CDATA[Reply to AWS Edukit as normal Core2 for  Uiflow on Mon, 28 Dec 2020 09:01:41 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/md" aria-label="Profile: md">@<bdi>md</bdi></a></p>
<p dir="auto">I don't have a AWS Edukit so my assumption might be incorrect, but comparing the schematics of the two (AWS Edukit and plain M5Core2) I cannot find a difference, except for some additional hardware in the AWS Edukit (e.g. secure element, LEDs). So a AWS Edukit with M5Core2 UIFlow installed should act like a plain M5Core2 just fine.</p>
<p dir="auto">To get M5Core2 UIFlow installed you can use <a href="https://m5stack.com/pages/download" target="_blank" rel="noopener noreferrer nofollow ugc">M5Burner</a> to flash <code>UIFlow_Core2</code> onto it.</p>
<p dir="auto">To go back you can reinstall AWS factory firmware. Follow the steps <a href="https://github.com/m5stack/Core2-for-AWS-IoT-EduKit/tree/master/Core2-for-AWS-IoT-EduKit-Factory-Firmware" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/11395</link><guid isPermaLink="true">https://community.m5stack.com/post/11395</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 28 Dec 2020 09:01:41 GMT</pubDate></item></channel></rss>
