<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wrong COM.X UART configuration stops Fire from turning on.]]></title><description><![CDATA[<p dir="auto">I purchased the COM.X LoRaWAN module for my Fire. The default UART pins are used for PSRAM. Fortunately the COM.X modules have dip switches to change the UART pins, so I changed them to the next group 15/13. Unfortunately this interferes with the LED bar of the M5GO base that comes with the Fire which uses pin 15.<br />
So I switched UART to the last group of pins 0/5. Then my Fire didn't want to turn on. After a bit of research I found that's probably because pin 0 is the boot pin of the ESP32, so the Fire always goes in boot mode.<br />
Now I use the weird setting of ports 13/5, since this is the only option that doesn't interfere with anything else. At least I hope so ..</p>
<p dir="auto">I think this should be mentioned in the documentation. I am not sure why pin 0 is even an option, since it should be the same issue on any core (1) devices. On core2 pin 0 also doesn't seem to be a good option.</p>
]]></description><link>https://community.m5stack.com/topic/2675/wrong-com-x-uart-configuration-stops-fire-from-turning-on</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 08:32:52 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2675.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Dec 2020 23:49:39 GMT</pubDate><ttl>60</ttl></channel></rss>
