<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PLC Proto Industrial, USB cable for programming]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am using the PLC for a project.</p>
<p dir="auto">When the PLC is connected to 12V power supply, is it safe to connect Core to computer with USB cable?</p>
<p dir="auto">Will the full project, assembled Core on PLC work with only Core on USB (without 12V power supply on PLC).</p>
<p dir="auto">And last question, what is the BAT pin on PLC circuit?</p>
<p dir="auto">Thank you!</p>
<p dir="auto">Will Core charge internal battery when the only power supply is 12V on PLC?</p>
]]></description><link>https://community.m5stack.com/topic/2680/plc-proto-industrial-usb-cable-for-programming</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 06:47:18 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2680.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 31 Dec 2020 13:46:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PLC Proto Industrial, USB cable for programming on Thu, 31 Dec 2020 16:06:13 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/leo05" aria-label="Profile: Leo05">@<bdi>Leo05</bdi></a></p>
<p dir="auto">have a look at the schematics of <a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/schematic/Core/M5-Core-Schematic(20171206).pdf" target="_blank" rel="noopener noreferrer nofollow ugc">M5Stack Core</a> and <a href="https://static-cdn.m5stack.com/image/product_jpg/assets/img/product_pics/base/plc_sch.jpg" target="_blank" rel="noopener noreferrer nofollow ugc">PLC</a>.</p>
<p dir="auto">I do not have the PLC module but I do have the LAN module which is similar in that respect and I do have both 12V and USB connected at the same time while programming the M5Stack Core, but not permanently. Both power sources produce 5 volts but there might be a slight difference in the voltage which would mean one power source is feeding a small current into the other, but I don't think it will damage anything. Nevertheless, use at your own risk.</p>
<p dir="auto">The full project, M5Stack Core and PLC module will work fine from USB only. Unless you add something in the PLC module which requires 12 volts.</p>
<p dir="auto">According to the PLC module schematics the BAT pin is not connected / used. But it will show the battery voltage from the stacked M5Stack Core.</p>
<p dir="auto">No, the battery in M5Stack Core will <strong>not</strong> charge when only 12V is applied. Only USB can charge the battery.</p>
]]></description><link>https://community.m5stack.com/post/11478</link><guid isPermaLink="true">https://community.m5stack.com/post/11478</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 31 Dec 2020 16:06:13 GMT</pubDate></item></channel></rss>
