<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rel. 1.7.0 COM.LTE network configuration]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/2672/uiflow-1-7-1">UIFlow 1.7.1</a><br />
Hi, I need to configure M5Stack-Core to use COM.LTE connectivity as shown <a href="https://twitter.com/its_hard_2_name/status/1334785139382001666/photo/4" target="_blank" rel="noopener noreferrer nofollow ugc">here</a><br />
Currently my <strong>Core</strong> mounts UIFlow <strong>1.7.0</strong> where that option is available in the device setup menu, but once selected did not work</p>
<li>Does it work also with Core or just on Core-2 ? Can I hope also to get it work on Core?</li>
<li>The M5Burner configuration of 1.7.0 does not offer that same extended option with COM.X as shown in the link above; Shall I upgrade to 1.7.1?</li>
<li>Where can I find the entire step-by-step setup procedure (shall I act on M5Burner as well as on device setup?)</li>
<p dir="auto">Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/2698/rel-1-7-0-com-lte-network-configuration</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:13:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2698.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 Jan 2021 08:20:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rel. 1.7.0 COM.LTE network configuration on Tue, 02 Feb 2021 11:28:15 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, indeed the root cause was an old version of M5Burner, which I did not realized there was a newer one. Once updated, then the configuration panel showed also the APN settings and the UIFlow firmware booted successfully with the LTE connectivity</p>
]]></description><link>https://community.m5stack.com/post/12241</link><guid isPermaLink="true">https://community.m5stack.com/post/12241</guid><dc:creator><![CDATA[teiafra]]></dc:creator><pubDate>Tue, 02 Feb 2021 11:28:15 GMT</pubDate></item><item><title><![CDATA[Reply to Rel. 1.7.0 COM.LTE network configuration on Thu, 28 Jan 2021 14:48:06 GMT]]></title><description><![CDATA[<p dir="auto">Hi, <a class="plugin-mentions-user plugin-mentions-a" href="/user/teiafra" aria-label="Profile: teiafra">@<bdi>teiafra</bdi></a> are you basically asking if the COM.LTE module is compatible with Core2 using UIFlow?</p>
<p dir="auto">regarding question 2, we always recommend using the latest version of M5Burner, which might solve some issues you are having.</p>
<p dir="auto">regarding the third question, you can find all the information about the COM.LTE device and it's usage at the documentation: <a href="http://docs.m5stack.com/#/en/module/comx_lte" target="_blank" rel="noopener noreferrer nofollow ugc">http://docs.m5stack.com/#/en/module/comx_lte</a></p>
<p dir="auto">The UIFLow tutorial can be found here: <a href="http://docs.m5stack.com/#/en/quick_start/comx_lte/network_over_com" target="_blank" rel="noopener noreferrer nofollow ugc">http://docs.m5stack.com/#/en/quick_start/comx_lte/network_over_com</a></p>
]]></description><link>https://community.m5stack.com/post/12089</link><guid isPermaLink="true">https://community.m5stack.com/post/12089</guid><dc:creator><![CDATA[Zontex]]></dc:creator><pubDate>Thu, 28 Jan 2021 14:48:06 GMT</pubDate></item><item><title><![CDATA[Reply to Rel. 1.7.0 COM.LTE network configuration on Tue, 12 Jan 2021 12:08:25 GMT]]></title><description><![CDATA[<p dir="auto">I'd like to show that the UIFLow 1.7.0 or 1.7.1 configuration mask does not present any panel related to ![configuration of COM.X](<img src="/assets/uploads/files/1610453188043-dd9cee4a-5335-42b0-9061-b6a886b59f8d-image.png" alt="0_1610453184058_dd9cee4a-5335-42b0-9061-b6a886b59f8d-image.png" class=" img-fluid img-markdown" /> image url) to be compared with the similar one posted  <a href="https://twitter.com/its_hard_2_name/status/1334785139382001666/photo/4" target="_blank" rel="noopener noreferrer nofollow ugc">on Twitter</a></p>
]]></description><link>https://community.m5stack.com/post/11680</link><guid isPermaLink="true">https://community.m5stack.com/post/11680</guid><dc:creator><![CDATA[teiafra]]></dc:creator><pubDate>Tue, 12 Jan 2021 12:08:25 GMT</pubDate></item></channel></rss>
