<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help to upgrade battery without any accessory for RGBW lamp project]]></title><description><![CDATA[<p dir="auto">I'm designing a battery-powered lamp for tables with M5StickC and,</p>
<li>Can I replace the 80mah lipo with a 3300mah? (I don't want to use the battery HAT)</li>
<li>How do I disassemble M5stickC beyond the 2 screws? (It's not easy to lift the board and get access to the battery.)</li>
<li>Are there libraries to program RGBW neopixels for UIFLOW?(<a href="https://www.adafruit.com/product/2858" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.adafruit.com/product/2858</a>)</li>
<p dir="auto">Thank you!</p>
]]></description><link>https://community.m5stack.com/topic/2735/help-to-upgrade-battery-without-any-accessory-for-rgbw-lamp-project</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:41:25 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2735.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Jan 2021 12:29:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help to upgrade battery without any accessory for RGBW lamp project on Fri, 15 Jan 2021 19:29:40 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/akshaypatil" aria-label="Profile: akshaypatil">@<bdi>akshaypatil</bdi></a></p>
<p dir="auto">yes, 'bat' and 'gnd'. I suggest you also check out the <a href="https://docs.m5stack.com/#/en/core/m5stickc?id=schematic" target="_blank" rel="noopener noreferrer nofollow ugc">M5StickC schematics</a>.</p>
<p dir="auto">Cheers<br />
]]></description><link>https://community.m5stack.com/post/11777</link><guid isPermaLink="true">https://community.m5stack.com/post/11777</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 15 Jan 2021 19:29:40 GMT</pubDate></item><item><title><![CDATA[Reply to Help to upgrade battery without any accessory for RGBW lamp project on Fri, 15 Jan 2021 18:20:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thank you! Sorry for the late reply, got busy with something.</p>
<p dir="auto">Which ports do I add the battery externally? To "bat" and "gnd"?<br />
I was going to leave it barebones since it's not easy to find an alternative esp32 pico kit with a battery charging circuit onboard. (tiny tiny size)<br />
Would be cool to have an esp32 mounted on top of a li-ion cell, like how they have the protection circuits.</p>
]]></description><link>https://community.m5stack.com/post/11774</link><guid isPermaLink="true">https://community.m5stack.com/post/11774</guid><dc:creator><![CDATA[akshaypatil]]></dc:creator><pubDate>Fri, 15 Jan 2021 18:20:37 GMT</pubDate></item><item><title><![CDATA[Reply to Help to upgrade battery without any accessory for RGBW lamp project on Thu, 14 Jan 2021 08:31:14 GMT]]></title><description><![CDATA[<p dir="auto">all you need to do is connect 5V directly to the led strip between the M5StickC and the led strip.<br />
<img src="https://i.stack.imgur.com/NE5Cl.png" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/11740</link><guid isPermaLink="true">https://community.m5stack.com/post/11740</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 14 Jan 2021 08:31:14 GMT</pubDate></item><item><title><![CDATA[Reply to Help to upgrade battery without any accessory for RGBW lamp project on Wed, 13 Jan 2021 15:30:34 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/akshaypatil" aria-label="Profile: akshaypatil">@<bdi>akshaypatil</bdi></a></p>
<li>
<p dir="auto">what exactly do you mean by 'replace'? You can 'attach/add' any battery on the outside, but almost any larger capacity battery will <strong>not</strong> mechanically fit inside M5StickC.</p>
</li>
<li>
<p dir="auto">AFAIK you cannot lift the two boards without separating them first - that is what I did when I took these <a href="https://www.gwendesign.ch/kb/m5stack/m5stickc/#inside-m5stickc" target="_blank" rel="noopener noreferrer nofollow ugc">pictures</a>.</p>
</li>
<li>
<p dir="auto">I don't know.</p>
</li>
]]></description><link>https://community.m5stack.com/post/11707</link><guid isPermaLink="true">https://community.m5stack.com/post/11707</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 13 Jan 2021 15:30:34 GMT</pubDate></item></channel></rss>
