<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core2 Port I2C Not Working]]></title><description><![CDATA[<p dir="auto">I have a grey core and have used the TOF sensor with success, utilizing UI-FLOW.  I just got a Core2 and burned UI-Flow into it.  When I attach the TOF sensor to port A it appears to not be able to be read on the I2C bus.  Any suggestions?<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/topic/2751/core2-port-i2c-not-working</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 23:31:01 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2751.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Jan 2021 03:57:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core2 Port I2C Not Working on Fri, 15 Jan 2021 19:44:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/se" aria-label="Profile: se">@<bdi>se</bdi></a> said in <a href="/post/11749">Core2 Port I2C Not Working</a>:</p>
<p dir="auto">Felix thanks for the suggestion.  You were absolutely correct version 1.7.0 resolved the problem.</p>
<p dir="auto">Now in 1.7.1.1 this problem was fixed.</p>
]]></description><link>https://community.m5stack.com/post/11778</link><guid isPermaLink="true">https://community.m5stack.com/post/11778</guid><dc:creator><![CDATA[OyczE]]></dc:creator><pubDate>Fri, 15 Jan 2021 19:44:43 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 Port I2C Not Working on Fri, 15 Jan 2021 01:41:47 GMT]]></title><description><![CDATA[<p dir="auto">Felix thanks for the suggestion.  You were absolutely correct version 1.7.0 resolved the problem.</p>
]]></description><link>https://community.m5stack.com/post/11749</link><guid isPermaLink="true">https://community.m5stack.com/post/11749</guid><dc:creator><![CDATA[SE]]></dc:creator><pubDate>Fri, 15 Jan 2021 01:41:47 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 Port I2C Not Working on Thu, 14 Jan 2021 07:15:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/se" aria-label="Profile: SE">@<bdi>SE</bdi></a></p>
<p dir="auto">please checkout this <a href="https://community.m5stack.com/topic/2663/core2-uiflow-bottom2-support/14">post</a>. It looks like M5Core2 UIFlow firmware 1.7.1 is broken in that respect, but 1.7.0 seems to work.</p>
]]></description><link>https://community.m5stack.com/post/11732</link><guid isPermaLink="true">https://community.m5stack.com/post/11732</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 14 Jan 2021 07:15:17 GMT</pubDate></item></channel></rss>
