<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Ideas, helping M5Stack document stuff...]]></title><description><![CDATA[<p dir="auto">Dear people at M5Stack,</p>
<p dir="auto">First of all: thank you for making cool things....</p>
<p dir="auto">But ehm... why don't we start using (for instance) the wiki at your Github repository to document them a little more? I realise you have a bunch of really busy engineers making products and not all speaking english, but if you really have no time to document, please just dump code, schematics, PCB designs, 3D CAD or whatever else and we'll help making it look pretty and tell people how it works in ways that they can understand. This helps us build stuff and having stuff documented well makes more people buy more product. Win/win, right?</p>
<p dir="auto">The alternative is that we start reverse-engineering your made-for-prototyping hardware. Which is doable, but a silly waste of time. Where are you located, and what are your documents written in? And are there volunteers here on the forum that speak Mandarin/Cantonese?</p>
<p dir="auto">My personal off-the-top-of-my-head wishlist...</p>
<li>
<p dir="auto">The schematics and any other documentation regarding the FACES keyboards and the plate underneath, so we can figure out if we can detect its presence and if/how we can trigger from software the reset-button double-click power off state that also turns off the keyboard. (If that is not triggerable from software, it probably should be in the next version.)</p>
</li>
<li>
<p dir="auto">Any internal data you have on battery charging (capacities, time needed, USB power modes supported, etc etc) for all three batteries (the small bottom plate that comes with the unit, the battery stackable unit and the FACES bottom.</p>
</li>
<li>
<p dir="auto">The thing with button A and wifi: which units does it affect, is the fix with the analogRead the best way, can one use speaker, button A and wifi at the same time without the squealing sound? Does it affect the newer units?</p>
</li>
<p dir="auto">But I am sure there is much more people can think about.</p>
<p dir="auto">This is, in my mind, the coolest tinkering hardware currently out there. I'd like to see it get critical mass and have a rapidly expanding ecosystem of stackable boards, software libraries etc, etc. This cannot all be done by a small group inside one company. You will have your own ideas of where you are taking this, and you have the benefit of seeing what actually sells in the market, but I think you would do even better if you also to talk to the rest of the world more.</p>
<hr />
<p dir="auto">Somewhat unrelated, but now that I'm talking to you anyway: here's some random ideas from myself or others in this community:</p>
<li>
<p dir="auto">The proto board and the other boards should have the pins on the other side of the connector accessible. ( maybe like <a href="http://forum.m5stack.com/topic/95/custom-prototype-board" target="_blank" rel="noopener noreferrer nofollow ugc">http://forum.m5stack.com/topic/95/custom-prototype-board</a> )</p>
</li>
<li>
<p dir="auto">In future versions of the stackable boards, more pins need to be solder-jumper options: too many pin conflicts already.</p>
</li>
<li>
<p dir="auto">Maybe sell a cheap OEM laserdiode barcode reader in a stackable module, looking out at the top of the screen, so with the FACES bottom it can be a handheld inventory device etc etc. (Or even a small camera, to be used as a camera or for QR and other 2D barcodes?)</p>
</li>
]]></description><link>https://community.m5stack.com/topic/276/ideas-helping-m5stack-document-stuff</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:11:06 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/276.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Aug 2018 07:04:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Fri, 23 Nov 2018 16:26:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> 在 <a href="/post/2066">Ideas, helping M5Stack document stuff...</a> 中说：</p>
<p dir="auto">Please read this doc. I updated it just now.</p>
<p dir="auto">It is better to see once than read 100 times bla-bla-bla</p>
]]></description><link>https://community.m5stack.com/post/2072</link><guid isPermaLink="true">https://community.m5stack.com/post/2072</guid><dc:creator><![CDATA[Kabron]]></dc:creator><pubDate>Fri, 23 Nov 2018 16:26:53 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Fri, 23 Nov 2018 13:04:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> 在 <a href="/post/2066">Ideas, helping M5Stack document stuff...</a> 中说：</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kabron" aria-label="Profile: kabron">@<bdi>kabron</bdi></a><br />
Hey kabron. Fire is not a topsecret. I consider that there are  few different between M5Core Basic, M5Core GRAY, M5Fire and the main board(M5Core WHITE) of M5GO. They are simliar to each other. So we just supply the schematic of M5Core Basic.<br />
Please read this doc. I updated it just now.<br />
<a href="https://github.com/m5stack/M5-Schematic/blob/master/Core/hardware_diff_between_m5cores.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-Schematic/blob/master/Core/hardware_diff_between_m5cores.md</a></p>
<p dir="auto">If it is not a secret, you should make the <strong>schematics of all the boards</strong> available. How hard can it be to put them on GitHub or somewhere else. Especially if you want those boards to be used by developers who want to do with them more than just playing with nice boxes.</p>
]]></description><link>https://community.m5stack.com/post/2071</link><guid isPermaLink="true">https://community.m5stack.com/post/2071</guid><dc:creator><![CDATA[loboris]]></dc:creator><pubDate>Fri, 23 Nov 2018 13:04:01 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Fri, 23 Nov 2018 09:08:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/playthegame" aria-label="Profile: playthegame">@<bdi>playthegame</bdi></a></p>
<table class="table table-bordered table-striped">
<thead>
<tr>
<th style="text-align:center">Device</th>
<th style="text-align:center">IIC address</th>
</tr>
</thead>
<tbody>
<tr>
<td style="text-align:center">mpu9250</td>
<td style="text-align:center">0x68</td>
</tr>
<tr>
<td style="text-align:center">mpu6050</td>
</tr>
<tr>
<td style="text-align:center">IP5306</td>
<td style="text-align:center">0x75</td>
</tr>
<tr>
<td style="text-align:center">MAG3110</td>
<td style="text-align:center">0x0E</td>
</tr>
</tbody>
</table>
<p dir="auto">the arly version of M5Fire was built in MPU6050 + MAGE3110, but we change MPU6050 + MAGE3110 to MPU9250.</p>
<p dir="auto">If your m5fire scan i2c address is 0x68 0x75 0x0e, it means your m5fire maybe is previous version.<br />
The iic addrss of new m5fire will be 0x68, 0x75<br />
The iic addrss of m5core basic will be  0x75, because it has not own mpu9250</p>
]]></description><link>https://community.m5stack.com/post/2068</link><guid isPermaLink="true">https://community.m5stack.com/post/2068</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Fri, 23 Nov 2018 09:08:01 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Fri, 23 Nov 2018 08:52:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/playthegame" aria-label="Profile: playthegame">@<bdi>playthegame</bdi></a><br />
Hi<br />
the GROVE Interface(I2C) of M5Camera is G12 and G13</p>
<p dir="auto">The IIC address of MPU9250 is 0x68</p>
<p dir="auto">Here's the docs about M5Fire and M5Camera</p>
<p dir="auto">M5Fire :<br />
<a href="https://m5stack.github.io/m5-docs/#/en/product_documents/m5stack-core/m5core_fire" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.github.io/m5-docs/#/en/product_documents/m5stack-core/m5core_fire</a></p>
<p dir="auto">M5Camera:<br />
<a href="https://m5stack.github.io/m5-docs/#/en/product_documents/units/unit_m5camera" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.github.io/m5-docs/#/en/product_documents/units/unit_m5camera</a></p>
<p dir="auto"><a href="https://github.com/m5stack/M5-Schematic/blob/master/Core/hardware_diff_between_m5cores.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-Schematic/blob/master/Core/hardware_diff_between_m5cores.md</a></p>
]]></description><link>https://community.m5stack.com/post/2067</link><guid isPermaLink="true">https://community.m5stack.com/post/2067</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Fri, 23 Nov 2018 08:52:40 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Fri, 23 Nov 2018 08:14:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kabron" aria-label="Profile: kabron">@<bdi>kabron</bdi></a><br />
]]></description><link>https://community.m5stack.com/post/2066</link><guid isPermaLink="true">https://community.m5stack.com/post/2066</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Fri, 23 Nov 2018 08:14:38 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Fri, 23 Nov 2018 07:32:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rop" aria-label="Profile: rop">@<bdi>rop</bdi></a><br />
OK, i am going to talk with our boss about that. Thanks your support.</p>
]]></description><link>https://community.m5stack.com/post/2065</link><guid isPermaLink="true">https://community.m5stack.com/post/2065</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Fri, 23 Nov 2018 07:32:29 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Tue, 20 Nov 2018 20:57:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a><br />
M5Fire schematics?<br />
Its fine to used the altered pin maps as basis but be aware your leaflets contain errors.<br />
Fire has an undocumented I2C device on the bus, most probably the power management IC.</p>
<p dir="auto">M5Camera really I2C SDA on G22 not G25? Schematics?</p>
<p dir="auto">M5Core<br />
Not up to date, connectors missing</p>
<p dir="auto">M BUS<br />
HPWR?</p>
]]></description><link>https://community.m5stack.com/post/2053</link><guid isPermaLink="true">https://community.m5stack.com/post/2053</guid><dc:creator><![CDATA[PlayTheGame]]></dc:creator><pubDate>Tue, 20 Nov 2018 20:57:21 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Tue, 20 Nov 2018 13:03:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> 在 <a href="/post/2045">Ideas, helping M5Stack document stuff...</a> 中说：</p>
<p dir="auto">I am adding  schematic files</p>
<p dir="auto">M5Fire schematic still TopSecret?</p>
]]></description><link>https://community.m5stack.com/post/2051</link><guid isPermaLink="true">https://community.m5stack.com/post/2051</guid><dc:creator><![CDATA[Kabron]]></dc:creator><pubDate>Tue, 20 Nov 2018 13:03:17 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Tue, 20 Nov 2018 11:49:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> Excellent!! Stuff is being added!! Could you also add the schematics, 3D, etc. of all the bases, including the FACES base and the FACES keyboards ?</p>
]]></description><link>https://community.m5stack.com/post/2050</link><guid isPermaLink="true">https://community.m5stack.com/post/2050</guid><dc:creator><![CDATA[Rop]]></dc:creator><pubDate>Tue, 20 Nov 2018 11:49:40 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Tue, 20 Nov 2018 01:40:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kabron" aria-label="Profile: kabron">@<bdi>kabron</bdi></a><br />
<p dir="auto"><a href="https://github.com/m5stack/M5-Schematic" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-Schematic</a></p>
<p dir="auto">Here a catalog<br />
<a href="https://github.com/m5stack/M5RepoCatalog" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5RepoCatalog</a></p>
]]></description><link>https://community.m5stack.com/post/2045</link><guid isPermaLink="true">https://community.m5stack.com/post/2045</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Tue, 20 Nov 2018 01:40:58 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Tue, 20 Nov 2018 01:38:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a><br />
I am fixing it.</p>
]]></description><link>https://community.m5stack.com/post/2044</link><guid isPermaLink="true">https://community.m5stack.com/post/2044</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Tue, 20 Nov 2018 01:38:54 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Mon, 19 Nov 2018 20:19:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> 在 <a href="/post/2026">Ideas, helping M5Stack document stuff...</a> 中说：</p>
<p dir="auto">To everyone:</p>
<p dir="auto">Please pay more attention to github and docs.</p>
<p dir="auto"><a href="https://github.com/m5stack" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack</a></p>
<p dir="auto"><a href="https://m5stack.github.io/m5-docs/#/en/product_documents" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.github.io/m5-docs/#/en/product_documents</a></p>
<p dir="auto">lots of 404 missing pages.</p>
]]></description><link>https://community.m5stack.com/post/2043</link><guid isPermaLink="true">https://community.m5stack.com/post/2043</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 19 Nov 2018 20:19:05 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Mon, 19 Nov 2018 11:29:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> 在 <a href="/post/2026">Ideas, helping M5Stack document stuff...</a> 中说：</p>
<p dir="auto">Schematics???</p>
]]></description><link>https://community.m5stack.com/post/2042</link><guid isPermaLink="true">https://community.m5stack.com/post/2042</guid><dc:creator><![CDATA[Kabron]]></dc:creator><pubDate>Mon, 19 Nov 2018 11:29:04 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Mon, 19 Nov 2018 07:39:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/playthegame" aria-label="Profile: playthegame">@<bdi>playthegame</bdi></a> 在 <a href="/post/2015">Ideas, helping M5Stack document stuff...</a> 中说：</p>
The forum is hosted by Alisoft (Alibaba group) in Hangzhou behind the great firewall. So something might trigger the behavior (keywords) intentional or not. The main site is hosted in Singapore and not affected.</p>
<p dir="auto">Ahh, The Great Firewall of China, I had forgotten about that.</p>
]]></description><link>https://community.m5stack.com/post/2033</link><guid isPermaLink="true">https://community.m5stack.com/post/2033</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 19 Nov 2018 07:39:48 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Mon, 19 Nov 2018 04:43:02 GMT]]></title><description><![CDATA[<p dir="auto">To everyone:</p>
]]></description><link>https://community.m5stack.com/post/2026</link><guid isPermaLink="true">https://community.m5stack.com/post/2026</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 19 Nov 2018 04:43:02 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Mon, 19 Nov 2018 04:40:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kabron" aria-label="Profile: kabron">@<bdi>kabron</bdi></a> Sorry, i am adding schematics for m5stack products.</p>
]]></description><link>https://community.m5stack.com/post/2025</link><guid isPermaLink="true">https://community.m5stack.com/post/2025</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 19 Nov 2018 04:40:44 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Sun, 18 Nov 2018 15:05:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a><br />
]]></description><link>https://community.m5stack.com/post/2015</link><guid isPermaLink="true">https://community.m5stack.com/post/2015</guid><dc:creator><![CDATA[PlayTheGame]]></dc:creator><pubDate>Sun, 18 Nov 2018 15:05:12 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Sun, 18 Nov 2018 14:34:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/playthegame" aria-label="Profile: playthegame">@<bdi>playthegame</bdi></a><br />
It happens every so often so I'm guessing that the forum is on an IPv4 server.</p>
]]></description><link>https://community.m5stack.com/post/2013</link><guid isPermaLink="true">https://community.m5stack.com/post/2013</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 18 Nov 2018 14:34:22 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Sun, 18 Nov 2018 14:24:57 GMT]]></title><description><![CDATA[<p dir="auto">There is also this very weird behavior, that <a href="http://forum.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">http://forum.m5stack.com</a> is giving a  timeout error from my IP address in the last week after I posted something here for 3 times. Well certainly coincidence, most certainly.<br />
After renewing my dynamic IP this forum loads immediately.</p>
]]></description><link>https://community.m5stack.com/post/2012</link><guid isPermaLink="true">https://community.m5stack.com/post/2012</guid><dc:creator><![CDATA[PlayTheGame]]></dc:creator><pubDate>Sun, 18 Nov 2018 14:24:57 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Sun, 18 Nov 2018 09:19:46 GMT]]></title><description><![CDATA[<p dir="auto">I have to agree. I love m5stack, but it seems they should work a little harder at supporting the excellent hardware things they have.</p>
]]></description><link>https://community.m5stack.com/post/2007</link><guid isPermaLink="true">https://community.m5stack.com/post/2007</guid><dc:creator><![CDATA[LastCaress]]></dc:creator><pubDate>Sun, 18 Nov 2018 09:19:46 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Sat, 17 Nov 2018 14:26:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/playthegame" aria-label="Profile: playthegame">@<bdi>playthegame</bdi></a> 在 <a href="/post/2004">Ideas, helping M5Stack document stuff...</a> 中说：</p>
<p dir="auto">I abandoned this platform for commercial prototypes because of lack of documentation. But at least there are now hints for more info in a new repository.<br />
<p dir="auto">I took a glance. Monstrous Poverty</p>
]]></description><link>https://community.m5stack.com/post/2005</link><guid isPermaLink="true">https://community.m5stack.com/post/2005</guid><dc:creator><![CDATA[Kabron]]></dc:creator><pubDate>Sat, 17 Nov 2018 14:26:34 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Sat, 17 Nov 2018 12:38:11 GMT]]></title><description><![CDATA[<p dir="auto">I abandoned this platform for commercial prototypes because of lack of documentation. But at least there are now hints for more info in a new repository.<br />
]]></description><link>https://community.m5stack.com/post/2004</link><guid isPermaLink="true">https://community.m5stack.com/post/2004</guid><dc:creator><![CDATA[PlayTheGame]]></dc:creator><pubDate>Sat, 17 Nov 2018 12:38:11 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Sat, 17 Nov 2018 12:02:50 GMT]]></title><description><![CDATA[<p dir="auto">Almost total documentation absence is of course a most deepest shame for M5 team.<br />
Now, receiving M5BALA, I try to compensate somehow this frustration.<br />
Here are schematic and inner pictures of the subject.<br />
<a href="https://yadi.sk/i/zVWDBtc4cuNTYQ" target="_blank" rel="noopener noreferrer nofollow ugc">https://yadi.sk/i/zVWDBtc4cuNTYQ</a><br />
<a href="https://yadi.sk/i/fBWXI_yBZRKNNA" target="_blank" rel="noopener noreferrer nofollow ugc">https://yadi.sk/i/fBWXI_yBZRKNNA</a><br />
<a href="https://yadi.sk/i/VaLjgC-To-Nzkw" target="_blank" rel="noopener noreferrer nofollow ugc">https://yadi.sk/i/VaLjgC-To-Nzkw</a><br />
<a href="https://yadi.sk/d/u1rtEiRjL0w6MQ" target="_blank" rel="noopener noreferrer nofollow ugc">https://yadi.sk/d/u1rtEiRjL0w6MQ</a></p>
<p dir="auto">Hope, other members join to  initiative</p>
]]></description><link>https://community.m5stack.com/post/2003</link><guid isPermaLink="true">https://community.m5stack.com/post/2003</guid><dc:creator><![CDATA[Kabron]]></dc:creator><pubDate>Sat, 17 Nov 2018 12:02:50 GMT</pubDate></item><item><title><![CDATA[Reply to Ideas, helping M5Stack document stuff... on Thu, 30 Aug 2018 16:52:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mkellner" aria-label="Profile: mkellner">@<bdi>mkellner</bdi></a> 在 <a href="/post/1460">Ideas, helping M5Stack document stuff...</a> 中说：</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> We need schematics for the modules too, please. I'd like to see it for the PLC module.</p>
<p dir="auto">I would like to see if for the PSramCam but I have only seen the proto schamtic</p>
]]></description><link>https://community.m5stack.com/post/1462</link><guid isPermaLink="true">https://community.m5stack.com/post/1462</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 30 Aug 2018 16:52:36 GMT</pubDate></item></channel></rss>
