<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Enable &quot;back button&quot; or &quot;cancel button&quot; in UIFlow main menu on device]]></title><description><![CDATA[<p dir="auto">I flashed my Core2 with UIFlow-v1.7.1.1-core2. By accident I pressed the middle button on the touchscreen, then I had to select USB or WiFi. Now I am stuck in this mode ("Download UIFlow Desktop IDE") and can not go back or exit this screen.</p>
<p dir="auto">I already re-flashed UIFlow again, but the Core2 still goes back to the screen after boot. I can not reset it back to start. It seems to store the state in an area that is not cleared when re-flashing.</p>
<p dir="auto"><strong>I can not get out of this screen. I can not reset the device to start over.</strong><br />
<img src="https://imgpile.com/images/7do7kj.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">It would be great to have an option to get out of the menu and back into the main menu of UIFlow on the device.</p>
]]></description><link>https://community.m5stack.com/topic/2760/enable-back-button-or-cancel-button-in-uiflow-main-menu-on-device</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 04:36:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2760.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Jan 2021 07:01:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Enable &quot;back button&quot; or &quot;cancel button&quot; in UIFlow main menu on device on Sun, 07 Mar 2021 06:43:22 GMT]]></title><description><![CDATA[<p dir="auto">I'm not sure if this helps, but when you are in M5Burner and you flash your Core2, next to the "Burn" button there is a "Configuration" button. In the popup, if you change the "Start Mode", does that get you out of the UiFlow screen on the Core2?</p>
]]></description><link>https://community.m5stack.com/post/12860</link><guid isPermaLink="true">https://community.m5stack.com/post/12860</guid><dc:creator><![CDATA[pop]]></dc:creator><pubDate>Sun, 07 Mar 2021 06:43:22 GMT</pubDate></item><item><title><![CDATA[Reply to Enable &quot;back button&quot; or &quot;cancel button&quot; in UIFlow main menu on device on Thu, 18 Feb 2021 03:07:42 GMT]]></title><description><![CDATA[<p dir="auto">The problem i think is that last uiflow mode selection is too quick and does not wait enough for the menu to make a change. I liked how on the StickC, you coul press button B and reset. that way you could force to change mode option.</p>
<p dir="auto">Hope they fix this. it is just matter of adding time to the menu or as you said a cancel or back option.</p>
]]></description><link>https://community.m5stack.com/post/12537</link><guid isPermaLink="true">https://community.m5stack.com/post/12537</guid><dc:creator><![CDATA[BricoMS]]></dc:creator><pubDate>Thu, 18 Feb 2021 03:07:42 GMT</pubDate></item><item><title><![CDATA[Reply to Enable &quot;back button&quot; or &quot;cancel button&quot; in UIFlow main menu on device on Sat, 16 Jan 2021 15:40:39 GMT]]></title><description><![CDATA[<p dir="auto">At least I am not stuck at that screen anymore, I updated M5Burner and now have the configuration for Core2 available, which enables setting the start mode (which survives a re-flash).</p>
]]></description><link>https://community.m5stack.com/post/11796</link><guid isPermaLink="true">https://community.m5stack.com/post/11796</guid><dc:creator><![CDATA[mb]]></dc:creator><pubDate>Sat, 16 Jan 2021 15:40:39 GMT</pubDate></item></channel></rss>
