<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cannot connect to M5Stick CPlus - no COM port driver - Windows 10 - actual software]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I have 2 M5Stick CPlus and want to use it.<br />
So I connect it to the USB port - 2 devices were not recognized !!<br />
In the device manager I can see "M5stack", but it is marked with a yello sign, means no driver present.<br />
I try to install the new version with the Windows update system -- no success !</p>
<p dir="auto">But:<br />
I driver is installed correct.<br />
My M5stack Fire and Basic are working - there is no error - I can use it with the UIflow, Burner and Arduino etc.<br />
If I change for example from the Fire to one of the M5Sticks CPlus (same cable, same USB port, same software), then the device manager of Windows 10 shows me a problem and the M5Stick is not connected via COM port.</p>
<p dir="auto">I get all software drivers new from <a href="http://M5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">M5stack.com</a> - deinstalled the old driver - start the computer new - installed the drivers again - used one other USB port - one other USB cable ------- NO SOLUTION  ----- NO CONNECTION.</p>
<p dir="auto">The M5Sticks CPlus are working.<br />
The preset software is working - all the preset demos are working - the battery is charges full.<br />
LED is blinking.<br />
I don't think it's a hardware problem, because it is the same  thing with 2 differernt devices.</p>
<p dir="auto">What have I to do ?<br />
Is there a special software I have to install ?</p>
<p dir="auto">regards<br />
K.D.</p>
]]></description><link>https://community.m5stack.com/topic/2762/cannot-connect-to-m5stick-cplus-no-com-port-driver-windows-10-actual-software</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 12:22:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2762.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Jan 2021 17:03:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cannot connect to M5Stick CPlus - no COM port driver - Windows 10 - actual software on Sun, 17 Jan 2021 17:27:08 GMT]]></title><description><![CDATA[<p dir="auto">so - I installed that driver -- and it works ! (on all of my PCs and notebook)<br />
Perfect !!</p>
<p dir="auto">I found that I have to burn the M5Flow UI 2 times.<br />
The first time the burn process was very fast (about 5s) and after that the device shows no reaction - screen black - no reaction on any key. (according to the PC display everything was ok - no error)<br />
The second time burning was about 5 times slower, but now every thing is as it should be. The M5Stick works and I can use UIFlow.</p>
<p dir="auto">Strange -- maybe sometime anybody can explain ........<br />
@sudoku: Thanks again for your help.</p>
K.D.</p>
]]></description><link>https://community.m5stack.com/post/11809</link><guid isPermaLink="true">https://community.m5stack.com/post/11809</guid><dc:creator><![CDATA[ramaker]]></dc:creator><pubDate>Sun, 17 Jan 2021 17:27:08 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot connect to M5Stick CPlus - no COM port driver - Windows 10 - actual software on Sun, 17 Jan 2021 10:51:50 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the answer.<br />
I try to download the driver, but It seems, that the site is down - so I'l try it tomorrow.</p>
<p dir="auto">I'm wondering, why M5Stack gives not the same information on the websit of the stick.<br />
Even if I'm a minority, but a hint would have prevented me from long time frustration. And the information is available and "costs" only one more line of text.<br />
Have a nice Sunday.<br />
K.D.</p>
<p dir="auto">p.s. I tried it on my 2 PCs and one notebook with Windows 10 (every hardware is different, HP and Lenovo) - on every PC / notbook the USB connection is not working.</p>
]]></description><link>https://community.m5stack.com/post/11804</link><guid isPermaLink="true">https://community.m5stack.com/post/11804</guid><dc:creator><![CDATA[ramaker]]></dc:creator><pubDate>Sun, 17 Jan 2021 10:51:50 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot connect to M5Stick CPlus - no COM port driver - Windows 10 - actual software on Sat, 16 Jan 2021 18:35:49 GMT]]></title><description><![CDATA[<p dir="auto">Fire and Basic use a different USB chip (CP210X). The StickC Plus uses a FTDI chip which should work out of the box in Windows 10. Someone with a similar problem had luck using the drivers from <a href="https://www.ftdichip.com/Drivers/VCP.htm" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.ftdichip.com/Drivers/VCP.htm</a></p>
]]></description><link>https://community.m5stack.com/post/11798</link><guid isPermaLink="true">https://community.m5stack.com/post/11798</guid><dc:creator><![CDATA[sodoku]]></dc:creator><pubDate>Sat, 16 Jan 2021 18:35:49 GMT</pubDate></item></channel></rss>
