<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there any document using UNIT V with UI Flow v1.6.6]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am pretty new with M5Stick, RoverC and UnitV using UI Flow v1.6.6 on Windows10.</p>
<p dir="auto">I found that the online tutorial does not contain the functions a in the UI Flow Menu. Seems lots on change such as Color Trace in the tutorial becomes Color Track with totally different functions as per the tutorial.</p>
<p dir="auto">How can I find the document for the latest version? Or in the other word, with the combination of  M5Stick, RoverC and UnitV, which version of the UI Flow that I can use with a proper ducument available?</p>
<p dir="auto">Thank you so much in advance for your help.</p>
]]></description><link>https://community.m5stack.com/topic/2781/is-there-any-document-using-unit-v-with-ui-flow-v1-6-6</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 15:41:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2781.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 Jan 2021 15:50:07 GMT</pubDate><ttl>60</ttl></channel></rss>
