<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MPU-6886 Questions &#x2F; Information]]></title><description><![CDATA[<p dir="auto">Good Day!</p>
<p dir="auto">I posted this under the core2 product page, but will post here also since this chip exists in more than just the Core2. Specifically:</p>
<li>
<p dir="auto">Why doesnt the Invensense website even list this chip? Is it custom made for M5Stack?</p>
</li>
<li>
<p dir="auto">Has anyone figured out how to properly set the offsets? I found a library that measures them and then applies them externally but not actually setting them on the chip. (For example, register 19&amp;20)</p>
</li>
<li>
<p dir="auto">I was trying to find the chip on the website to determine if there were any further application notes or suggestions. Other Chips like the MPU-6050 have a DMP (Digital Motion Processor) component that would be great for gesture offloading. It doesn't appear this chip has this based on the datasheet listed on the M5 website)</p>
</li>
<li>
<p dir="auto">Any Tips on calibrating these? Mine has a lot of noise when laying on a flat surface which I'm trying to reduce.</p>
</li>
<li>
<p dir="auto">While reviewing the datasheet, it appears that the XA_OFFSET registers are 15bit signed ints not 16. It appears that most of the popular libraries written for the 6050, 9250  have this mapping incorrect.</p>
</li>
]]></description><link>https://community.m5stack.com/topic/2825/mpu-6886-questions-information</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 03:46:01 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2825.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Jan 2021 18:12:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MPU-6886 Questions &#x2F; Information on Tue, 17 Jan 2023 17:22:44 GMT]]></title><description><![CDATA[<p dir="auto">Check out the code on my implementation on <a href="https://github.com/febalci/seismoM5" target="_blank" rel="noopener noreferrer nofollow ugc">M5 Seismometer</a>. I only worked on accelerometer, not gyro, but the calibration method is the same. You can also find the datasheet under /doc folder.</p>
]]></description><link>https://community.m5stack.com/post/19886</link><guid isPermaLink="true">https://community.m5stack.com/post/19886</guid><dc:creator><![CDATA[febz11]]></dc:creator><pubDate>Tue, 17 Jan 2023 17:22:44 GMT</pubDate></item><item><title><![CDATA[Reply to MPU-6886 Questions &#x2F; Information on Thu, 02 Sep 2021 09:21:21 GMT]]></title><description><![CDATA[<p dir="auto">about this chip function and register only could refer this file.   if in this datasheet has some register not included,  maybe it is not supported.</p>
<p dir="auto"><a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/core/MPU-6886-000193%2Bv1.1_GHIC_en.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/core/MPU-6886-000193%2Bv1.1_GHIC_en.pdf</a></p>
<p dir="auto">about the calibrating,  you could refer to this balance car project.   maybe you could find something you want.</p>
<p dir="auto"><a href="https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Application/Bala2" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Application/Bala2</a></p>
]]></description><link>https://community.m5stack.com/post/14788</link><guid isPermaLink="true">https://community.m5stack.com/post/14788</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 02 Sep 2021 09:21:21 GMT</pubDate></item><item><title><![CDATA[Reply to MPU-6886 Questions &#x2F; Information on Tue, 31 Aug 2021 19:50:33 GMT]]></title><description><![CDATA[<p dir="auto">I'm still hopeful that some day I will get an answer to my questions!</p>
<p dir="auto">I've emailed support and also not received an answer but I'm going to keep checking every day!</p>
]]></description><link>https://community.m5stack.com/post/14781</link><guid isPermaLink="true">https://community.m5stack.com/post/14781</guid><dc:creator><![CDATA[revta]]></dc:creator><pubDate>Tue, 31 Aug 2021 19:50:33 GMT</pubDate></item></channel></rss>
