<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do you change volume on Core2]]></title><description><![CDATA[<p dir="auto">Under "Speaker" in UIFLOW there is the ability to play wave files but the next step is to obviously change volume.  Does anyone know how to change volume on a Core2 in UIFLOW or Python?</p>
]]></description><link>https://community.m5stack.com/topic/2845/how-do-you-change-volume-on-core2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:29:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2845.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Jan 2021 12:54:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do you change volume on Core2 on Sat, 30 Jan 2021 17:16:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bobolink" aria-label="Profile: bobolink">@<bdi>bobolink</bdi></a> FYI to myself<br />
If you have an engineering background--part of Micropython--<br />
module 'dba:  calculate dBA (A-weighting decibels) from an input stream of digital audio samples<br />
module 'i2stools':  function to efficiently extract sample data from a buffer filled by I2S<br />
Signal processing (logical shifts--fractional multiply) on the PCM samples instead of hardware volume control gets the job done also.</p>
]]></description><link>https://community.m5stack.com/post/12189</link><guid isPermaLink="true">https://community.m5stack.com/post/12189</guid><dc:creator><![CDATA[bobolink]]></dc:creator><pubDate>Sat, 30 Jan 2021 17:16:45 GMT</pubDate></item><item><title><![CDATA[Reply to How do you change volume on Core2 on Fri, 29 Jan 2021 13:00:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zontex" aria-label="Profile: zontex">@<bdi>zontex</bdi></a> OK thanks for the reply. I guess you could set the volume of the .WAV files in the pc program “Audacity”.<br />
But user volume control would be nice.</p>
]]></description><link>https://community.m5stack.com/post/12156</link><guid isPermaLink="true">https://community.m5stack.com/post/12156</guid><dc:creator><![CDATA[bobolink]]></dc:creator><pubDate>Fri, 29 Jan 2021 13:00:53 GMT</pubDate></item><item><title><![CDATA[Reply to How do you change volume on Core2 on Fri, 29 Jan 2021 04:01:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/se" aria-label="Profile: se">@<bdi>se</bdi></a> Hi, This is core2 not grey, core2 doesn't support for now due to some bug we have to resolve that makes background noise. if you try normal core it will work just fine.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bobolink" aria-label="Profile: bobolink">@<bdi>bobolink</bdi></a> currently we don't support C/C++ API for it.</p>
]]></description><link>https://community.m5stack.com/post/12138</link><guid isPermaLink="true">https://community.m5stack.com/post/12138</guid><dc:creator><![CDATA[Zontex]]></dc:creator><pubDate>Fri, 29 Jan 2021 04:01:45 GMT</pubDate></item><item><title><![CDATA[Reply to How do you change volume on Core2 on Thu, 28 Jan 2021 17:21:12 GMT]]></title><description><![CDATA[<p dir="auto">On the Grey Core UIFLOW there is a volume command but on under the CORE2 Beta UIFLOW I cannot find one.  Here is a screenshot.  Let me know what you think.  Thanks <img src="/assets/uploads/files/1611854429915-image_2021-01-28_122026-resized.png" alt="0_1611854426492_image_2021-01-28_122026.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/12124</link><guid isPermaLink="true">https://community.m5stack.com/post/12124</guid><dc:creator><![CDATA[SE]]></dc:creator><pubDate>Thu, 28 Jan 2021 17:21:12 GMT</pubDate></item><item><title><![CDATA[Reply to How do you change volume on Core2 on Thu, 28 Jan 2021 15:52:41 GMT]]></title><description><![CDATA[<p dir="auto">Is there a C/C++ way to set volume?</p>
]]></description><link>https://community.m5stack.com/post/12121</link><guid isPermaLink="true">https://community.m5stack.com/post/12121</guid><dc:creator><![CDATA[bobolink]]></dc:creator><pubDate>Thu, 28 Jan 2021 15:52:41 GMT</pubDate></item><item><title><![CDATA[Reply to How do you change volume on Core2 on Thu, 28 Jan 2021 15:08:52 GMT]]></title><description><![CDATA[<p dir="auto">Hello, under hardware -&gt; speaker -&gt; there is a block called "setVolume" that you can use to change the volume of your Core device :)</p>
]]></description><link>https://community.m5stack.com/post/12108</link><guid isPermaLink="true">https://community.m5stack.com/post/12108</guid><dc:creator><![CDATA[Zontex]]></dc:creator><pubDate>Thu, 28 Jan 2021 15:08:52 GMT</pubDate></item></channel></rss>
