<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to use the RGB LEDs of FACE II ?]]></title><description><![CDATA[<p dir="auto">How to use the RGB LEDs of FACE II with a CORE2 or a CORE Gray with UIFlow 1.7.2? I tested in HARDWARES / RGB but it doesn't work with my two COREs, while everything works with the BOTTOM2.</p>
<p dir="auto"><img src="/assets/uploads/files/1612004722643-d52db766-41ea-44c2-ba84-af21972eecb4-image.png" alt="0_1612004723226_d52db766-41ea-44c2-ba84-af21972eecb4-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/2866/how-to-use-the-rgb-leds-of-face-ii</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 19:35:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2866.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Jan 2021 11:05:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to use the RGB LEDs of FACE II ? on Wed, 03 Feb 2021 20:15:24 GMT]]></title><description><![CDATA[<p dir="auto">I finally found the problem ... putting the screws on my FACE II it works. Probably a false contact</p>
]]></description><link>https://community.m5stack.com/post/12282</link><guid isPermaLink="true">https://community.m5stack.com/post/12282</guid><dc:creator><![CDATA[Arno]]></dc:creator><pubDate>Wed, 03 Feb 2021 20:15:24 GMT</pubDate></item><item><title><![CDATA[Reply to How to use the RGB LEDs of FACE II ? on Sun, 31 Jan 2021 13:14:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thanks a lot for your answer. there is no problem to use the 4 leds of the joystick, but there are also 2 X 5 leds on the base of the FACE II. I can't find how to use them with UIFlow.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a> Thank you for the information on the non-compatibility of FACE II with CORE 2. I will only use it with CORE Gray, mais je n'ai encore trouvé comment utiliser les leds du FACE II, but I have not yet found how to use the LEDs of FACE II with UIFlow.</p>
]]></description><link>https://community.m5stack.com/post/12204</link><guid isPermaLink="true">https://community.m5stack.com/post/12204</guid><dc:creator><![CDATA[Arno]]></dc:creator><pubDate>Sun, 31 Jan 2021 13:14:10 GMT</pubDate></item><item><title><![CDATA[Reply to How to use the RGB LEDs of FACE II ? on Sun, 31 Jan 2021 01:13:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arno" aria-label="Profile: arno">@<bdi>arno</bdi></a> said in <a href="/post/12185">How to use the RGB LEDs of FACE II ?</a>:</p>
<p dir="auto">I don’t have the Faces hardware either, but from what I have read, the Faces and Faces II bottoms are only for the original Core hardware (Black/Grey/Fire/Go). It might be misleading by the name, but Faces II is not compatible with the Core2 (at least in reference to controlling the LEDs).</p>
<p dir="auto">Similar to the M5GO Bottom (original Cores) and Bottom2 (Core2 only).</p>
<p dir="auto">Looking at the schematics and examples, Faces II and M5GO Bottom have the 10 LEDs on GPIO 15. The M5GO Bottom2 has the 10 LEDs on GPIO 25.</p>
<p dir="auto">Having said all that, I’m surprised your Core Grey does <em>not</em> work with your Faces II. Can you test again?</p>
<p dir="auto">You also said everything works with the Bottom2. I’m surprised your Grey works with the Bottom2???... because it shouldn’t (website says Core2 only).</p>
]]></description><link>https://community.m5stack.com/post/12196</link><guid isPermaLink="true">https://community.m5stack.com/post/12196</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sun, 31 Jan 2021 01:13:58 GMT</pubDate></item><item><title><![CDATA[Reply to How to use the RGB LEDs of FACE II ? on Sat, 30 Jan 2021 23:51:42 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/arno" aria-label="Profile: Arno">@<bdi>Arno</bdi></a></p>
<p dir="auto">have you tried: FACES - Encoder - Set LED Pos... or FACES - Joystick - Set LED Pos...? (Just guessing here as I don't have any FACES hardware.)</p>
]]></description><link>https://community.m5stack.com/post/12194</link><guid isPermaLink="true">https://community.m5stack.com/post/12194</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 30 Jan 2021 23:51:42 GMT</pubDate></item></channel></rss>
