<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Fire battery LED blinking - no function of the core]]></title><description><![CDATA[<p dir="auto">I connect the Fire to an USB cable - with the connector of the charging unit - not Fire USB - over night - more than 10h.<br />
The red LED of the akku modul starts blinking red.<br />
But I cannot turn the Fire unit on.</p>
<p dir="auto">If I connect the USB direct to the Fire unit, then the Fire core is working.</p>
<p dir="auto">I think the akku is "dead". (Strange I used it about 1h - not more)<br />
Or is there a trick to bring the system back to live ?<br />
K.D.</p>
]]></description><link>https://community.m5stack.com/topic/2870/m5stack-fire-battery-led-blinking-no-function-of-the-core</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 03:11:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2870.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 Jan 2021 10:16:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Fire battery LED blinking - no function of the core on Fri, 25 Jun 2021 16:00:24 GMT]]></title><description><![CDATA[<p dir="auto">Hello<br />
had the same problem.<br />
Solution with me, Use an older 5V USB power supply.<br />
The new ones switch off due to insufficient power consumption.<br />
Motorola review 2020<br />
low A. = off<br />
Samsung<br />
v. 2015<br />
no problem.<br />
Try old power supplies without high-performance charge control.</p>
<p dir="auto">73/ Klaus</p>
]]></description><link>https://community.m5stack.com/post/14245</link><guid isPermaLink="true">https://community.m5stack.com/post/14245</guid><dc:creator><![CDATA[DO1KPR]]></dc:creator><pubDate>Fri, 25 Jun 2021 16:00:24 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Fire battery LED blinking - no function of the core on Sun, 31 Jan 2021 12:42:59 GMT]]></title><description><![CDATA[<p dir="auto">I erased the flash of the Fire core and load it new with UIFlow V1.7.2 (the same version as before) and now everything works !!??</p>
<p dir="auto">Is was not easy - because at the beginnning there were time-out errors - the burner software can't connect.<br />
Strange - because the download and execution of skeches from UIflow worked.</p>
<p dir="auto">If powered the Fire down - wait 30min - shut down windows complete.<br />
After new start I could erase the Fire core - but here were a long time delay until the software can connect and erase - about 5s.<br />
Now I could flash UIflow - but again it seems, that the burner has to wait. The process was about doubble the time compared with my M5Stack Faces.</p>
<p dir="auto">Now the akkus in both modeles are loaded and the Fire core works with the akku power - like it should be.</p>
<p dir="auto">Strange !!! What has a firmware update to do with connecting to akku and the way of power supply for the core ?</p>
]]></description><link>https://community.m5stack.com/post/12202</link><guid isPermaLink="true">https://community.m5stack.com/post/12202</guid><dc:creator><![CDATA[ramaker]]></dc:creator><pubDate>Sun, 31 Jan 2021 12:42:59 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Fire battery LED blinking - no function of the core on Sun, 31 Jan 2021 10:43:40 GMT]]></title><description><![CDATA[<p dir="auto">I checked it with a GoPlus2 module - it has an akku included too.<br />
The same effect.<br />
As long as I connect the Fire to the USB it's working and the LED inside the GoPlus2 modul is on (green)<br />
Disconnect USB - no LED on - no function.</p>
<p dir="auto">Now I think, that the Fire core has a problem.</p>
<p dir="auto">Is there anything with which I can check the Fire core ?</p>
<p dir="auto">I wrote a litte UIflow block, using the battery blocks of UIflow.<br />
It shows me:<br />
"charging"<br />
"not full charged"<br />
"battery level 100%"</p>
<p dir="auto">So , there should be power in the akku ----- or ?</p>
<p dir="auto">K.D.</p>
]]></description><link>https://community.m5stack.com/post/12200</link><guid isPermaLink="true">https://community.m5stack.com/post/12200</guid><dc:creator><![CDATA[ramaker]]></dc:creator><pubDate>Sun, 31 Jan 2021 10:43:40 GMT</pubDate></item></channel></rss>
