<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack &#x2F; GPS &#x2F; UIFlow]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
I am a newbie in this forum as well as regarding M5Stack.<br />
As Newbie I start with the M5Stack fire in combination with UIFLow/Blocky.</p>
<p dir="auto">I read about the limitation and possible workarounds reagarding M5Stack Fire with a GPS sensor.<br />
Is there a solution in the meantime, that can be approached via UIFlow?<br />
So far I couldn`t integrate the GPS sensor via UiFlow.</p>
<p dir="auto">Thanks,<br />
Uli</p>
]]></description><link>https://community.m5stack.com/topic/2876/m5stack-gps-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 10:34:08 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2876.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Jan 2021 16:38:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack &#x2F; GPS &#x2F; UIFlow on Mon, 22 Feb 2021 13:57:26 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/uli" aria-label="Profile: Uli">@<bdi>Uli</bdi></a></p>
<p dir="auto">When you say 'GPS sensor' what is the exact hardware you have? Do you have a GPS Module or a GPS Unit from M5Stack or a device from another vendor?</p>
<p dir="auto">What do you mean exactly by 'limitations and possible workarounds'? Where did you read about it?</p>
<p dir="auto">I do not own a GPS Module or GPS Unit so I cannot test it myself, but when I select M5Stack Fire as device in UIFlow 1.7.2 I do see support for both.</p>
]]></description><link>https://community.m5stack.com/post/12606</link><guid isPermaLink="true">https://community.m5stack.com/post/12606</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 22 Feb 2021 13:57:26 GMT</pubDate></item></channel></rss>
