<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Port &quot;E&quot;, Port &quot;Custom&quot; and Pogo]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">Port "E",  where can I find it?</p>
<p dir="auto">Port "Custom", these are pins from the bus, right?</p>
<p dir="auto">Pogo pins, they are only for charging, right - using them as interface is not possible?</p>
<p dir="auto">Sorry for these question, but due to my experience regarding docu - its poor - the available docu ;-)</p>
<p dir="auto">KR,<br />
Uli</p>
]]></description><link>https://community.m5stack.com/topic/2878/port-e-port-custom-and-pogo</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 10:34:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2878.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 Jan 2021 13:45:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Port &quot;E&quot;, Port &quot;Custom&quot; and Pogo on Tue, 02 Feb 2021 14:31:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uli" aria-label="Profile: uli">@<bdi>uli</bdi></a> said in <a href="/post/12232">Port "E", Port "Custom" and Pogo</a>:</p>
<p dir="auto">According to the product page, the pogo pins can also be used for I2C (GPIO 21 and 22) on supported devices (BALA)<br />
<a href="https://docs.m5stack.com/#/en/base/m5go_bottom?id=pinmap" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/base/m5go_bottom?id=pinmap</a></p>
]]></description><link>https://community.m5stack.com/post/12242</link><guid isPermaLink="true">https://community.m5stack.com/post/12242</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Tue, 02 Feb 2021 14:31:38 GMT</pubDate></item><item><title><![CDATA[Reply to Port &quot;E&quot;, Port &quot;Custom&quot; and Pogo on Mon, 01 Feb 2021 21:29:10 GMT]]></title><description><![CDATA[<p dir="auto">Port "Custom" is used for defining pins that are not set as the default port A B and C.<br />
For example, if you wanted to connect an 2nd unit to a stickC you would chose the custom and then set the tx and rx pins to two of the pins from the hat connector.<br />
As to port E well, I'm yet to find out.</p>
]]></description><link>https://community.m5stack.com/post/12236</link><guid isPermaLink="true">https://community.m5stack.com/post/12236</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 01 Feb 2021 21:29:10 GMT</pubDate></item></channel></rss>
