<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DC Motor AKA Lego+ not working in uiFlow?]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/2055/legoboard">LegoBoard</a></p>
<p dir="auto">Having updated everything (v1.7.2 for the firmware, and using the beta as well as the non-beta v1.4.5 of the uiFlow), I cannot seem to make the Lego+ (AKA DC Motor in the newer UI) work. All I get is "legoBoard not support in uiflow" on the LCD of the M5 Core unit.</p>
<p dir="auto">I remember it did work a long time ago. What changed, and more importantly: how to fix this?</p>
]]></description><link>https://community.m5stack.com/topic/2897/dc-motor-aka-lego-not-working-in-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 16:16:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2897.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Feb 2021 11:59:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to DC Motor AKA Lego+ not working in uiFlow? on Fri, 05 Feb 2021 23:36:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> That actually worked. Not an ideal situation as I cannot use the newer units, but for now the Lego motors turn again which is awesome!<br />
Thanks a lot! I downgraded the UI, but it never occured to me that I should downgrade the firmware too.</p>
]]></description><link>https://community.m5stack.com/post/12330</link><guid isPermaLink="true">https://community.m5stack.com/post/12330</guid><dc:creator><![CDATA[hkubota]]></dc:creator><pubDate>Fri, 05 Feb 2021 23:36:22 GMT</pubDate></item><item><title><![CDATA[Reply to DC Motor AKA Lego+ not working in uiFlow? on Fri, 05 Feb 2021 13:04:52 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/hkubota" aria-label="Profile: hkubota">@<bdi>hkubota</bdi></a></p>
<p dir="auto">yes, it looks like Lego+ has been broken in recent firmware as I get the same error on M5Stack Gray or M5Core2 running 1.7.2 firmware. However when I burn 1.4.5 firmware onto my M5Stack Gray I get a different error stating that the Lego module maybe isn't connected (which is correct as I don't have a Lego module).</p>
<p dir="auto">It might be worth trying to burn 1.4.5 firmware onto your M5Stack and try again.</p>
]]></description><link>https://community.m5stack.com/post/12309</link><guid isPermaLink="true">https://community.m5stack.com/post/12309</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 05 Feb 2021 13:04:52 GMT</pubDate></item></channel></rss>
