<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to install MicroPython libraries? (HTTP GET with query parameters)]]></title><description><![CDATA[<p dir="auto"><strong>I would like to do a simple HTTP GET requests with key-value params.</strong></p>
<p dir="auto">This seems not supported by urequests, I found a recommended work-around:</p>
<pre><code>import urequests
from urllib.parse import urlencode
def get(url, params=None, **kw):
    if params:
        url = url.rstrip('?') + '?' + urlencode(params, doseq=True)
    return urequests.get(url, **kw)
payload = {'key1': 'value1', 'key2': ['value2', 'value3']}
res = get('http://httpbin.org/get', payload)
print(res.json())
<p dir="auto">Sadly <code>urllib.parse</code> from <a href="https://github.com/micropython/micropython-lib" target="_blank" rel="noopener noreferrer nofollow ugc">micropython-lib</a> is not included in M5Stack MicroPython.</p>
<p dir="auto"><strong>How can I install a MicroPython library onto my Core2?</strong> I am currently using <a href="thonny.org">Thonny IDE</a>.</p>
]]></description><link>https://community.m5stack.com/topic/2911/how-to-install-micropython-libraries-http-get-with-query-parameters</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 22:12:01 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2911.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Feb 2021 15:46:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to install MicroPython libraries? (HTTP GET with query parameters) on Mon, 08 Feb 2021 20:54:29 GMT]]></title><description><![CDATA[<p dir="auto">Well, and there is always the option to just strip <a href="https://github.com/micropython/micropython-lib/blob/master/urllib.parse/urllib/parse.py" target="_blank" rel="noopener noreferrer nofollow ugc">it</a> down to the basics.</p>
<pre><code># urlencode.py
_ALWAYS_SAFE = frozenset(b'ABCDEFGHIJKLMNOPQRSTUVWXYZ'
                         b'abcdefghijklmnopqrstuvwxyz'
                         b'0123456789'
                         b'_.-')
_ALWAYS_SAFE_BYTES = bytes(_ALWAYS_SAFE)
def quote(string, safe='/', encoding=None, errors=None):
    """quote('abc def') -&gt; 'abc%20def'
    Each part of a URL, e.g. the path info, the query, etc., has a
    different set of reserved characters that must be quoted.
    RFC 2396 Uniform Resource Identifiers (URI): Generic Syntax lists
    the following reserved characters.
    reserved    = ";" | "/" | "?" | ":" | "@" | "&amp;" | "=" | "+" |
    Each of these characters is reserved in some component of a URL,
    but not necessarily in all of them.
    By default, the quote function is intended for quoting the path
    section of a URL.  Thus, it will not encode '/'.  This character
    is reserved, but in typical usage the quote function is being
    called on a path where the existing slash characters are used as
    string and safe may be either str or bytes objects. encoding must
    not be specified if string is a str.
    The optional encoding and errors parameters specify how to deal with
    non-ASCII characters, as accepted by the str.encode method.
    By default, encoding='utf-8' (characters are encoded with UTF-8), and
    errors='strict' (unsupported characters raise a UnicodeEncodeError).
    if isinstance(string, str):
        if not string:
            return string
        if encoding is None:
            encoding = 'utf-8'
        if errors is None:
            errors = 'strict'
        string = string.encode(encoding, errors)
    else:
        if encoding is not None:
            raise TypeError("quote() doesn't support 'encoding' for bytes")
        if errors is not None:
            raise TypeError("quote() doesn't support 'errors' for bytes")
    return quote_from_bytes(string, safe)
def quote_plus(string, safe='', encoding=None, errors=None):
    """Like quote(), but also replace ' ' with '+', as required for quoting
    HTML form values. Plus signs in the original string are escaped unless
    they are included in safe. It also does not have safe default to '/'.
    # Check if ' ' in string, where string may either be a str or bytes.  If
    # there are no spaces, the regular quote will produce the right answer.
    if ((isinstance(string, str) and ' ' not in string) or
        (isinstance(string, bytes) and b' ' not in string)):
        return quote(string, safe, encoding, errors)
    if isinstance(safe, str):
        space = ' '
    else:
        space = b' '
    string = quote(string, safe + space, encoding, errors)
    return string.replace(' ', '+')
def quote_from_bytes(bs, safe='/'):
    """Like quote(), but accepts a bytes object rather than a str, and does
    not perform string-to-bytes encoding.  It always returns an ASCII string.
    quote_from_bytes(b'abc def\x3f') -&gt; 'abc%20def%3f'
    if not isinstance(bs, (bytes, bytearray)):
        raise TypeError("quote_from_bytes() expected bytes")
    if not bs:
        return ''
        # Normalize 'safe' by converting to bytes and removing non-ASCII chars
        safe = safe.encode('ascii', 'ignore')
    else:
        safe = bytes([c for c in safe if c &lt; 128])
    if not bs.rstrip(_ALWAYS_SAFE_BYTES + safe):
        return bs.decode()
    try:
        quoter = _safe_quoters[safe]
    except KeyError:
        _safe_quoters[safe] = quoter = Quoter(safe).__getitem__
    return ''.join([quoter(char) for char in bs])
def urlencode(query, doseq=False, safe='', encoding=None, errors=None):
    """Encode a dict or sequence of two-element tuples into a URL query string.
    If any values in the query arg are sequences and doseq is true, each
    sequence element is converted to a separate parameter.
    If the query arg is a sequence of two-element tuples, the order of the
    parameters in the output will match the order of parameters in the
    input.
    The components of a query arg may each be either a string or a bytes type.
    When a component is a string, the safe, encoding and error parameters are
    sent to the quote_plus function for encoding.
    if hasattr(query, "items"):
        query = query.items()
    else:
        # It's a bother at times that strings and string-like objects are
        # sequences.
        try:
            # non-sequence items should not work with len()
            # non-empty strings will fail this
            if len(query) and not isinstance(query[0], tuple):
                raise TypeError
            # Zero-length sequences of all types will get here and succeed,
            # but that's a minor nit.  Since the original implementation
            # allowed empty dicts that type of behavior probably should be
            # preserved for consistency
        except TypeError:
#            ty, va, tb = sys.exc_info()
            raise TypeError("not a valid non-string sequence "
                            "or mapping object")#.with_traceback(tb)
    l = []
    if not doseq:
        for k, v in query:
            if isinstance(k, bytes):
                k = quote_plus(k, safe)
            else:
                k = quote_plus(str(k), safe, encoding, errors)
            if isinstance(v, bytes):
                v = quote_plus(v, safe)
            else:
                v = quote_plus(str(v), safe, encoding, errors)
            l.append(k + '=' + v)
    else:
        for k, v in query:
            else:
            elif isinstance(v, str):
                v = quote_plus(v, safe, encoding, errors)
            else:
                try:
                    # Is this a sufficient test for sequence-ness?
                    x = len(v)
                except TypeError:
                    # not a sequence
                else:
                    # loop over the sequence
                    for elt in v:
                        if isinstance(elt, bytes):
                            elt = quote_plus(elt, safe)
                        else:
                            elt = quote_plus(str(elt), safe, encoding, errors)
                        l.append(k + '=' + elt)
    return '&amp;'.join(l)
<p dir="auto">Then we can finally do a nicer GET with parameters:</p>
from urlencode import urlencode
url = 'http://server.tld/path/to'
params = {'key1': 'value1', 'key2': 'value2'}
if params:
print(url)
response = urequests.get(url)
]]></description><link>https://community.m5stack.com/post/12364</link><guid isPermaLink="true">https://community.m5stack.com/post/12364</guid><dc:creator><![CDATA[mb]]></dc:creator><pubDate>Mon, 08 Feb 2021 20:54:29 GMT</pubDate></item><item><title><![CDATA[Reply to How to install MicroPython libraries? (HTTP GET with query parameters) on Mon, 08 Feb 2021 20:46:19 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, <a class="plugin-mentions-user plugin-mentions-a" href="/user/ksprayberry" aria-label="Profile: ksprayberry">@<bdi>ksprayberry</bdi></a>, I can manually transfer files. I just thought there was a <code>upip</code> or something on the device which can be used from the REPL.</p>
]]></description><link>https://community.m5stack.com/post/12362</link><guid isPermaLink="true">https://community.m5stack.com/post/12362</guid><dc:creator><![CDATA[mb]]></dc:creator><pubDate>Mon, 08 Feb 2021 20:46:19 GMT</pubDate></item><item><title><![CDATA[Reply to How to install MicroPython libraries? (HTTP GET with query parameters) on Mon, 08 Feb 2021 17:51:43 GMT]]></title><description><![CDATA[<p dir="auto">See if this helps.</p>
<p dir="auto"><a href="https://youtu.be/bdyZx2KC54Y" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/bdyZx2KC54Y</a></p>
]]></description><link>https://community.m5stack.com/post/12361</link><guid isPermaLink="true">https://community.m5stack.com/post/12361</guid><dc:creator><![CDATA[ksprayberry]]></dc:creator><pubDate>Mon, 08 Feb 2021 17:51:43 GMT</pubDate></item></channel></rss>
