<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Core2] M5Timer-Lib &#x2F;&#x2F; How to use &quot;numTimer&quot; in e.g. &quot;setInterval()&quot;]]></title><description><![CDATA[<p dir="auto">I want to use the M5Timer Library with Core2.<br />
In &lt;M5Timer.h&gt; there are functions having a &lt;numTimer&gt; argument and those without.</p>
<p dir="auto">Questions:<br />
How can I use<br />
<img src="/assets/uploads/files/1612800102947-89beb75e-65e8-4440-ba61-01fbb4c67451-image.png" alt="0_1612800101761_89beb75e-65e8-4440-ba61-01fbb4c67451-image.png" class=" img-fluid img-markdown" /><br />
with a certain timer?<br />
I am simply missing the argument "numTimer" in the function.</p>
<p dir="auto">A working example for Core2 would be helpful.<br />
Thank you in advance.</p>
]]></description><link>https://community.m5stack.com/topic/2918/core2-m5timer-lib-how-to-use-numtimer-in-e-g-setinterval</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 16:18:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2918.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Feb 2021 16:06:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Core2] M5Timer-Lib &#x2F;&#x2F; How to use &quot;numTimer&quot; in e.g. &quot;setInterval()&quot; on Wed, 10 Feb 2021 14:47:05 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wa-berlin" aria-label="Profile: wa-berlin">@<bdi>wa-berlin</bdi></a></p>
<p dir="auto">you can't. Functions w/o <code>numTimer</code> argument will return the <em>internal</em> number assigned to a specific timer. You don't have direct control about which timer gets which number, but you can keep a record of the number assigned to a given timer to further manipulate it.</p>
<p dir="auto">Below is an example with 2 timers (A and B). Timer A counts up ever 2 seconds, whereas timer B counts up every second and stops at 10.</p>
<p dir="auto">With button A you can enable and disable timer A.<br />
With button B you can restart timer B once it has stopped.</p>
<pre><code>#include &lt;M5Core2.h&gt;
#include &lt;utility/M5Timer.h&gt;
M5Timer M5T;
int mytimerA = -1;
int mytimerB = -1;
int mycountA = 0;
int mycountB = 0;
void myTimerACB(void)
  mycountA++;
void myTimerBCB(void)
  mycountB++;
void setup()
  M5.begin();
  M5.Lcd.setTextSize(3);
  mytimerA = M5T.setInterval(2000, myTimerACB);
  mytimerB = M5T.setTimer(1000, myTimerBCB, 10);
void loop()
  M5.update();
  M5T.run();
  if(M5.BtnA.wasPressed() == true)
    if(M5T.isEnabled(mytimerA) == true)
      M5T.disable(mytimerA);
    else
      M5T.enable(mytimerA);
  if(M5.BtnB.wasPressed() == true)
    if(M5T.isEnabled(mytimerB) == false)
      M5T.deleteTimer(mytimerB);
      mycountB = 0;
  M5.Lcd.setCursor(0, 0);
  M5.Lcd.printf("Timer A: %s\n", M5T.isEnabled(mytimerA) ? "enabled " : "disabled");
  M5.Lcd.printf("Timer A: %04d", mycountA);
  M5.Lcd.setCursor(0, 100);
  M5.Lcd.printf("Timer B: %s\n", M5T.isEnabled(mytimerB) ? "enabled " : "disabled");
  M5.Lcd.printf("Timer B: %04d", mycountB);
<p dir="auto">Good luck!<br />
]]></description><link>https://community.m5stack.com/post/12415</link><guid isPermaLink="true">https://community.m5stack.com/post/12415</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 10 Feb 2021 14:47:05 GMT</pubDate></item></channel></rss>
