<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I hope this is she right place. I have M5StickC nits But It seems stuck  or something]]></title><description><![CDATA[<p dir="auto">I hope this is the right place. I have M5StickC nits But It seems stuck or something I'm trying to program them to use as Tally lights talking the Blackmagic ATEM switcher. I tried to follow a few examples on the internet. the main problem for most of the time was that I couple even get my macs to work with it at all.  I finally got access to a windows machine and got the project to verify then It said it uploaded.  Or so I thought. I just had a very bark grey screen and the light was stuck on. I assume that this may have something with not having access to the switcher. So I got the switcher and put it on the network where it could be seen from the M5 and rebooted it using the side button and still just a dark screen and the light stuck on. Now the Arduino software on the windows machine doesn't see it either. It used to show up as COM 3 but now nothing.</p>
]]></description><link>https://community.m5stack.com/topic/2921/i-hope-this-is-she-right-place-i-have-m5stickc-nits-but-it-seems-stuck-or-something</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 09:03:55 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2921.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Feb 2021 03:11:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I hope this is she right place. I have M5StickC nits But It seems stuck  or something on Wed, 10 Feb 2021 10:05:24 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/calmasacow" aria-label="Profile: calmasacow">@<bdi>calmasacow</bdi></a></p>
<p dir="auto">I get the impression you are trying to do to many things at once. May I suggest you start slow and take it step by step?</p>
<li>first make sure you can upload a program from your computer successfully and multiple times</li>
<li>start with a simple program like <a href="https://github.com/m5stack/M5StickC/tree/master/examples/Basics/HelloWorld" target="_blank" rel="noopener noreferrer nofollow ugc">this</a></li>
<li>then try to modify it, for instance by changing the text</li>
<p dir="auto">Only if above steps work reliably it makes sense to continue with your own stuff.</p>
<p dir="auto">Good luck!<br />
]]></description><link>https://community.m5stack.com/post/12410</link><guid isPermaLink="true">https://community.m5stack.com/post/12410</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 10 Feb 2021 10:05:24 GMT</pubDate></item></channel></rss>
