<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5GO firmware v0.1.6 aborts with GUIDE screen]]></title><description><![CDATA[<p dir="auto">I recently updated the M5GO firmware to v 0.1.6. This version has the problem that MicroPython suddenly aborts. This problem is reproduced by leaving M5GO on the GUIDE screen and leaving it for ten or more seconds.</p>
<p dir="auto">The following is the serial output when an abort occurs.</p>
<pre><code>configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4848
ho 0 tail 12 room 4
load:0x40078000,len:7324
load:0x40080000,len:7076
entry 0x40080348
Internal FS (SPIFFS): Mounted on partition 'internalfs' [size: 2686976; Flash address: 0x170000]
Filesystem size: 2462464 B
           Used: 928000 B
           Free: 1534464 B
Device ID:30aea45878e4
LCD initializing...Done!
[7882] State change: STA_STARTUP ===&gt; STA_GUIDE
Task watchdog got triggered. The following tasks did not reset the watchdog in time:
 - IDLE (CPU 1)
Tasks currently running:
CPU 0: IDLE
CPU 1: mp_task
Aborting.
abort() was called at PC 0x400d3d97 on core 0
Backtrace: 0x400920ec:0x3ffb0fb0 0x400922c3:0x3ffb0fd0 0x400d3d97:0x3ffb0ff0 0x40082741:0x3ffb1010 0x401b670f:0x00000000
Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
]]></description><link>https://community.m5stack.com/topic/293/m5go-firmware-v0-1-6-aborts-with-guide-screen</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 20:46:49 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/293.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Aug 2018 16:45:20 GMT</pubDate><ttl>60</ttl></channel></rss>
