<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cables for motor - 4 Channels DC Encoder Motor driver module - from where ?? (NO LEGO)]]></title><description><![CDATA[<p dir="auto">I want to connect 4 motors with encoder ( no LEGO motors !) to that module.<br />
I found, that M5stack is using 6pol connector with <strong>1mm space</strong> between the pins and all motors with encoder are using bigger connectors - 6pol with <strong>2mm space</strong> between the pins.<br />
(signals are equal - a standard 1:1 cable should work)</p>
<p dir="auto">So I cannot use standard cables.</p>
<p dir="auto">On the advertisement picture M5Stack is showing an encoder motor, that is directly connected to the module with a cable. This is exactly what I want.</p>
<p dir="auto">I asked the tech support from M5Stack - no reply ??</p>
<p dir="auto">Does anybody knows where I can get the motors or the adapter cables from ?</p>
<p dir="auto">I wonder why M5Stack is using these non standard connectors and is not offering a cable to connect to standard motors. (they only offer cables for LEGO - this is NOT want I want.)<br />
K.D.</p>
]]></description><link>https://community.m5stack.com/topic/2937/cables-for-motor-4-channels-dc-encoder-motor-driver-module-from-where-no-lego</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:48:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2937.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Feb 2021 08:57:39 GMT</pubDate><ttl>60</ttl></channel></rss>
