<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5stack Fire - no check code for binding device]]></title><description><![CDATA[<p dir="auto">Hi all!</p>
<p dir="auto">I hope this question is not too simple. I finally got my new m5stack fire, unboxed it, connected first to the m5-wifi then entered my SSID and let the device reboot. The next step would be to bind the m5stack to my io.m5stack with the check code. BUT: where is this code? The m5stack just shows either a rock paper scissor button test or a screen with some lessons and the information, that no device has been connected yet. No code anywhere to be seen. I am sure, I am just missing something very simple but anyhow - its a blocking point that prevents me from the acutal coding. ;-)</p>
<p dir="auto">Thanks for your support.<br />
Caly.</p>
]]></description><link>https://community.m5stack.com/topic/294/m5stack-fire-no-check-code-for-binding-device</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 16:53:08 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/294.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Aug 2018 06:56:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5stack Fire - no check code for binding device on Sat, 29 Sep 2018 05:49:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a> Thank you for your comment.  I'll see Youtube later.</p>
]]></description><link>https://community.m5stack.com/post/1627</link><guid isPermaLink="true">https://community.m5stack.com/post/1627</guid><dc:creator><![CDATA[soogie]]></dc:creator><pubDate>Sat, 29 Sep 2018 05:49:41 GMT</pubDate></item><item><title><![CDATA[Reply to M5stack Fire - no check code for binding device on Thu, 27 Sep 2018 02:25:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/soogie" aria-label="Profile: soogie">@<bdi>soogie</bdi></a> there is information on burning the firmware for mac operating system in the link that <a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> sent. Alternatively we also made a youtube video showing you how to burn the firmware on Mac <a href="https://www.youtube.com/watch?v=oEiFLsukAEE&amp;t=5s" target="_blank" rel="noopener noreferrer nofollow ugc">here</a></p>
]]></description><link>https://community.m5stack.com/post/1607</link><guid isPermaLink="true">https://community.m5stack.com/post/1607</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 27 Sep 2018 02:25:12 GMT</pubDate></item><item><title><![CDATA[Reply to M5stack Fire - no check code for binding device on Wed, 26 Sep 2018 16:03:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a> Thank you, but I use mac.<br />
I will look for some way to burn ith my mac.</p>
]]></description><link>https://community.m5stack.com/post/1603</link><guid isPermaLink="true">https://community.m5stack.com/post/1603</guid><dc:creator><![CDATA[soogie]]></dc:creator><pubDate>Wed, 26 Sep 2018 16:03:15 GMT</pubDate></item><item><title><![CDATA[Reply to M5stack Fire - no check code for binding device on Sun, 23 Sep 2018 07:56:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mynameisdavehi" aria-label="Profile: mynameisdavehi">@<bdi>mynameisdavehi</bdi></a> Hello<br />
Try to burn a M5GO firmware please.<br />
This is the article about how to burn a firmware<br />
<a href="https://m5stack.readthedocs.io/en/latest/get-started/how_to_burn_firmware_en.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.readthedocs.io/en/latest/get-started/how_to_burn_firmware_en.html</a></p>
]]></description><link>https://community.m5stack.com/post/1579</link><guid isPermaLink="true">https://community.m5stack.com/post/1579</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Sun, 23 Sep 2018 07:56:59 GMT</pubDate></item><item><title><![CDATA[Reply to M5stack Fire - no check code for binding device on Sun, 23 Sep 2018 07:56:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/soogie" aria-label="Profile: soogie">@<bdi>soogie</bdi></a> Hello<br />
]]></description><link>https://community.m5stack.com/post/1578</link><guid isPermaLink="true">https://community.m5stack.com/post/1578</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Sun, 23 Sep 2018 07:56:50 GMT</pubDate></item><item><title><![CDATA[Reply to M5stack Fire - no check code for binding device on Fri, 07 Sep 2018 18:12:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/soogie" aria-label="Profile: soogie">@<bdi>soogie</bdi></a> me three :(</p>
]]></description><link>https://community.m5stack.com/post/1492</link><guid isPermaLink="true">https://community.m5stack.com/post/1492</guid><dc:creator><![CDATA[mynameisdavehi]]></dc:creator><pubDate>Fri, 07 Sep 2018 18:12:54 GMT</pubDate></item><item><title><![CDATA[Reply to M5stack Fire - no check code for binding device on Wed, 05 Sep 2018 13:57:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calypticus" aria-label="Profile: calypticus">@<bdi>calypticus</bdi></a> Hi, I just have bumped into the same problem as you.</p>
]]></description><link>https://community.m5stack.com/post/1484</link><guid isPermaLink="true">https://community.m5stack.com/post/1484</guid><dc:creator><![CDATA[soogie]]></dc:creator><pubDate>Wed, 05 Sep 2018 13:57:13 GMT</pubDate></item></channel></rss>
