<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC - Can&#x27;t access USB Mode]]></title><description><![CDATA[<p dir="auto">I just recieved my M5StickC a few days ago. Since then I'm trying to figure out how to access usb mode in order to upload my code. Unfortunately the steps listet in the manual (<a href="https://docs.m5stack.com/#/en/quick_start/m5stickc/m5stickc_quick_start_with_uiflow" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/quick_start/m5stickc/m5stickc_quick_start_with_uiflow</a>) don't work. On boot the stick shows an M5 animation and then switches to the MPU6886 screen.</p>
<p dir="auto">Buttons A and B are both only cycling through the preinstalled "apps". Holding button B and hitting the restart button only starts the stick in "Test Mode" with a few more apps available, but the settings menu is not available.</p>
<p dir="auto">Because of this I can't use the device, what is really annoying me right now. Does anyone know how to actually get into the settings menu or had similar issues?</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://community.m5stack.com/topic/2948/m5stickc-can-t-access-usb-mode</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:12:29 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2948.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Feb 2021 18:39:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC - Can&#x27;t access USB Mode on Sun, 14 Feb 2021 11:47:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/capatinshimapan" aria-label="Profile: capatinshimapan">@<bdi>capatinshimapan</bdi></a> When you switch on the StickC after burning the firmware you need to immediatly press the "A" button to access the setting menu.<br />
In the setting press button a to go into mode and be to move to usb mode and press a to select usb mode.<br />
Press the reset button and it should boot into usb mode.</p>
]]></description><link>https://community.m5stack.com/post/12488</link><guid isPermaLink="true">https://community.m5stack.com/post/12488</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 14 Feb 2021 11:47:10 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC - Can&#x27;t access USB Mode on Sat, 13 Feb 2021 13:01:04 GMT]]></title><description><![CDATA[<p dir="auto">Probably you have installed factory test firmware written in c/arduino which doing only what you described in your post. You must flash device with uiflow firmware. Then you could run your stickc in app mode or programming mode.</p>
]]></description><link>https://community.m5stack.com/post/12480</link><guid isPermaLink="true">https://community.m5stack.com/post/12480</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Sat, 13 Feb 2021 13:01:04 GMT</pubDate></item></channel></rss>
