<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Have the camera, what now.]]></title><description><![CDATA[<p dir="auto">Just recieved my M5esp camera today but what do I do with it?<br />
As typical, information is lacking.</p>
]]></description><link>https://community.m5stack.com/topic/295/have-the-camera-what-now</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:40:30 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/295.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Aug 2018 17:22:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Have the camera, what now. on Fri, 24 Aug 2018 16:00:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoney" aria-label="Profile: stoney">@<bdi>stoney</bdi></a> 在 <a href="/post/1435">Have the camera, what now.</a> 中说：</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a></p>
<p dir="auto">Huh ?</p>
<p dir="auto">192.168.4.1/jpg_stream</p>
<p dir="auto">Does not work</p>
<p dir="auto">Then next post you say it works ? You are being confusing lol, you can edit the posts if you want..</p>
<p dir="auto">Nope it doesn't work however, reading the source code that you linked to and a bit of probing, I found the other info but mine seems to have overheated and died.<br />
I need to find someone to solder in some wires to bypass the usb&gt;usart chip and I just cant get it to work.<br />
Is it supposed to only draw 0.1A?<br />
Just trying to work out why the esp32 is running hot.</p>
]]></description><link>https://community.m5stack.com/post/1437</link><guid isPermaLink="true">https://community.m5stack.com/post/1437</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 24 Aug 2018 16:00:21 GMT</pubDate></item><item><title><![CDATA[Reply to Have the camera, what now. on Fri, 24 Aug 2018 14:11:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a></p>
]]></description><link>https://community.m5stack.com/post/1435</link><guid isPermaLink="true">https://community.m5stack.com/post/1435</guid><dc:creator><![CDATA[stoney]]></dc:creator><pubDate>Fri, 24 Aug 2018 14:11:09 GMT</pubDate></item><item><title><![CDATA[Reply to Have the camera, what now. on Fri, 24 Aug 2018 14:04:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a></p>
<p dir="auto">ohhhh...</p>
<p dir="auto">you have a typo in your "faulty post" , I thought you meant is was messy soldering but works.</p>
<p dir="auto">I must have recieved a faulty unit. the led next to the camera <strong>does</strong> light up</p>
]]></description><link>https://community.m5stack.com/post/1434</link><guid isPermaLink="true">https://community.m5stack.com/post/1434</guid><dc:creator><![CDATA[stoney]]></dc:creator><pubDate>Fri, 24 Aug 2018 14:04:59 GMT</pubDate></item><item><title><![CDATA[Reply to Have the camera, what now. on Thu, 23 Aug 2018 20:24:13 GMT]]></title><description><![CDATA[<p dir="auto">OK, mine seams to be dead however I have found the following.<br />
<a href="http://192.168.4.1" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.4.1</a> is the address.<br />
<a href="http://192.168.4.1:80" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.4.1:80</a> is the only open port.<br />
<a href="http://192.168.4.1/pgm" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.4.1/pgm</a> grayscale image.<br />
<a href="http://192.168.4.1/bmp_stream" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.4.1/bmp_stream</a> - BMP stream.<br />
<a href="http://192.168.4.1/jpg_stream" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.4.1/jpg_stream</a> - jpg stream.</p>
]]></description><link>https://community.m5stack.com/post/1433</link><guid isPermaLink="true">https://community.m5stack.com/post/1433</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 23 Aug 2018 20:24:13 GMT</pubDate></item><item><title><![CDATA[Reply to Have the camera, what now. on Thu, 23 Aug 2018 18:33:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> 在 <a href="/post/1431">Have the camera, what now.</a> 中说：</p>
<p dir="auto">Does not work.</p>
]]></description><link>https://community.m5stack.com/post/1432</link><guid isPermaLink="true">https://community.m5stack.com/post/1432</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 23 Aug 2018 18:33:59 GMT</pubDate></item><item><title><![CDATA[Reply to Have the camera, what now. on Thu, 23 Aug 2018 15:32:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoney" aria-label="Profile: stoney">@<bdi>stoney</bdi></a> 在 <a href="/post/1430">Have the camera, what now.</a> 中说：</p>
<p dir="auto">the schematic can be found on this page <a href="https://github.com/m5stack/M5Stack-UserGuide/blob/master/ESP32CAM.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Stack-UserGuide/blob/master/ESP32CAM.md</a></p>
<p dir="auto">The empty footprints are bottom left of page 2, the MPU60x0 (gyro ) and SPQ2410HR5H which appears to be a microphone.  I might try fitting an electret later and connecting it to pad 4, gain might be an issue though.<br />
I have seen old ads for them listed with the extra parts fitted for 3 times the price of this module, I think now sold out.<br />
The flux is normal and no big deal, if the LED works then it is not shorted by solder blobs, mine did not come with a lens cover either, the price for the entire module with ESP32 is cheaper than what I can buy the camera for, not expecting gold class here :)</p>
<p dir="auto">oh, the "demo" software as mentioned by jeff above sets it up in access point mode and then you can open either 192.168.4.1/jpg for a single image grab or 192.168.4.1/jpg_stream for a live feed</p>
<p dir="auto">the firmware is also on the page I linked, the page was branched from a previous demo by igrr and nothing has been edited so it does not properly explain either the hardware setup or the firmware, ie .. there is no ascii image output..</p>
<p dir="auto">Wait, the advertised gyro is missing?<br />
I put the test meter across the LED, the led is shorted (it's not even flat on the pcb!</p>
]]></description><link>https://community.m5stack.com/post/1431</link><guid isPermaLink="true">https://community.m5stack.com/post/1431</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 23 Aug 2018 15:32:00 GMT</pubDate></item><item><title><![CDATA[Reply to Have the camera, what now. on Thu, 23 Aug 2018 14:43:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a></p>
]]></description><link>https://community.m5stack.com/post/1430</link><guid isPermaLink="true">https://community.m5stack.com/post/1430</guid><dc:creator><![CDATA[stoney]]></dc:creator><pubDate>Thu, 23 Aug 2018 14:43:52 GMT</pubDate></item><item><title><![CDATA[Reply to Have the camera, what now. on Thu, 23 Aug 2018 04:40:16 GMT]]></title><description><![CDATA[<p dir="auto">Power it up. Look on your Wifi for an SSID like M5Cam. Connect your WiFI to it.<br />
FInd the IP Address, mine was 192.168.4.1<br />
Run a browser, I used Chrome, and type 192.168.4.1<br />
Away you go.</p>
]]></description><link>https://community.m5stack.com/post/1429</link><guid isPermaLink="true">https://community.m5stack.com/post/1429</guid><dc:creator><![CDATA[Jeff_Lusher]]></dc:creator><pubDate>Thu, 23 Aug 2018 04:40:16 GMT</pubDate></item><item><title><![CDATA[Reply to Have the camera, what now. on Sat, 25 Aug 2018 17:13:55 GMT]]></title><description><![CDATA[<p dir="auto">I must have recieved a faulty unit. the led next to the camera doesn't light up (looks shorted with solder) and there is flux puddles all over it!<br />
not to mention that there was not cover on the lens and loads of empty solder points.</p>
]]></description><link>https://community.m5stack.com/post/1428</link><guid isPermaLink="true">https://community.m5stack.com/post/1428</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 25 Aug 2018 17:13:55 GMT</pubDate></item><item><title><![CDATA[Reply to Have the camera, what now. on Tue, 21 Aug 2018 19:06:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/loboris" aria-label="Profile: loboris">@<bdi>loboris</bdi></a> 在 <a href="/post/1422">Have the camera, what now.</a> 中说：</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> 在 <a href="/post/1420">Have the camera, what now.</a> 中说：</p>
<p dir="auto">Just recieved my M5esp camera today but what do I do with it?</p>
<p dir="auto">Just wondering, why have you ordered one, not knowing what to do with it?</p>
<p dir="auto">I'm actually hoping that it will prove smaller and better then a rpizero+camera option.</p>
]]></description><link>https://community.m5stack.com/post/1424</link><guid isPermaLink="true">https://community.m5stack.com/post/1424</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 21 Aug 2018 19:06:19 GMT</pubDate></item><item><title><![CDATA[Reply to Have the camera, what now. on Tue, 21 Aug 2018 18:24:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/loboris" aria-label="Profile: loboris">@<bdi>loboris</bdi></a> 在 <a href="/post/1422">Have the camera, what now.</a> 中说：</p>
<p dir="auto">Err yes,<br />
I have idea but the lack of information on it is proving difficult.<br />
I plug in the usb and the thing runs hot (no leds)<br />
I connect to it and it downloads data but shows nothing on screen.<br />
It produces a file that ends in .jpg.download</p>
]]></description><link>https://community.m5stack.com/post/1423</link><guid isPermaLink="true">https://community.m5stack.com/post/1423</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 21 Aug 2018 18:24:01 GMT</pubDate></item><item><title><![CDATA[Reply to Have the camera, what now. on Tue, 21 Aug 2018 18:19:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> 在 <a href="/post/1420">Have the camera, what now.</a> 中说：</p>
]]></description><link>https://community.m5stack.com/post/1422</link><guid isPermaLink="true">https://community.m5stack.com/post/1422</guid><dc:creator><![CDATA[loboris]]></dc:creator><pubDate>Tue, 21 Aug 2018 18:19:12 GMT</pubDate></item></channel></rss>
