<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[the block &quot;int from bytes&quot; is incorrect.]]></title><description><![CDATA[<p dir="auto">the block "int from bytes" is incorrect.</p>
<p dir="auto">Automatic generation is           data = int.from_bytes(data, big)<br />
the correction is                        data = int.from_bytes(data, 'big')</p>
]]></description><link>https://community.m5stack.com/topic/3008/the-block-int-from-bytes-is-incorrect</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 11:39:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3008.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 25 Feb 2021 14:20:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to the block &quot;int from bytes&quot; is incorrect. on Thu, 11 Mar 2021 20:44:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hunterpark" aria-label="Profile: hunterpark">@<bdi>hunterpark</bdi></a>   Yes. I am Facing same issue. each time we need to modify and run. after restarting UIflow again reset back default. I want to modify existing code to rectify  as temporary solution. but it is bunch of JScript code and didn't  understand how to proceed further.</p>
]]></description><link>https://community.m5stack.com/post/12939</link><guid isPermaLink="true">https://community.m5stack.com/post/12939</guid><dc:creator><![CDATA[hitosnap]]></dc:creator><pubDate>Thu, 11 Mar 2021 20:44:40 GMT</pubDate></item></channel></rss>
