<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[JoyC won&#x27;t work with newer M5StickCPlus]]></title><description><![CDATA[<p dir="auto">I bought two M5StickCPlus to use with JoyC and BugC...but the JoyC program won't compile on  M5StickCPlus.<br />
I cannot use them, I do not want to order an old one. When will this be addressed by M5Stack?</p>
]]></description><link>https://community.m5stack.com/topic/3034/joyc-won-t-work-with-newer-m5stickcplus</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 07:40:51 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3034.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 Mar 2021 02:03:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to JoyC won&#x27;t work with newer M5StickCPlus on Thu, 04 Mar 2021 10:07:58 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a></p>
<p dir="auto">getting it to compile is probably as easy as replacing <code>#include &lt;M5StickC.h&gt;</code> with <code>#include &lt;M5StickCPlus.h&gt;</code>. The bigger issue is the larger screen size which will need to be adapted properly. If and when M5Stack engineers will fix that I have no idea. Sorry.</p>
]]></description><link>https://community.m5stack.com/post/12799</link><guid isPermaLink="true">https://community.m5stack.com/post/12799</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 04 Mar 2021 10:07:58 GMT</pubDate></item></channel></rss>
