<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2 Relay on PaHub]]></title><description><![CDATA[<p dir="auto">Hello everyone, I would like to switch the relay separately using PaHub 2 and can't get any further. Does anyone have an example here of using the PaHub with Relay?</p>
]]></description><link>https://community.m5stack.com/topic/3037/2-relay-on-pahub</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 19:46:18 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3037.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 Mar 2021 16:55:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 2 Relay on PaHub on Fri, 05 Mar 2021 06:56:56 GMT]]></title><description><![CDATA[<p dir="auto">You should be able to run up to 5 relay units connected to the i/ohub (pbhub).</p>
]]></description><link>https://community.m5stack.com/post/12820</link><guid isPermaLink="true">https://community.m5stack.com/post/12820</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 05 Mar 2021 06:56:56 GMT</pubDate></item><item><title><![CDATA[Reply to 2 Relay on PaHub on Thu, 04 Mar 2021 19:47:31 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/mad23" aria-label="Profile: mad23">@<bdi>mad23</bdi></a></p>
<p dir="auto">have you considered using the <a href="https://m5stack.com/collections/m5-unit/products/4-relay-unit" target="_blank" rel="noopener noreferrer nofollow ugc">4 relay unit</a>?</p>
]]></description><link>https://community.m5stack.com/post/12815</link><guid isPermaLink="true">https://community.m5stack.com/post/12815</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 04 Mar 2021 19:47:31 GMT</pubDate></item><item><title><![CDATA[Reply to 2 Relay on PaHub on Thu, 04 Mar 2021 19:14:38 GMT]]></title><description><![CDATA[<p dir="auto">Hello felmue, thank you for your answer.<br />
@All benefit I want 2 con this relay:<br />
<a href="https://docs.m5stack.com/#/en/unit/relay" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/unit/relay</a><br />
Does anyone have an idea?</p>
]]></description><link>https://community.m5stack.com/post/12814</link><guid isPermaLink="true">https://community.m5stack.com/post/12814</guid><dc:creator><![CDATA[mad23]]></dc:creator><pubDate>Thu, 04 Mar 2021 19:14:38 GMT</pubDate></item><item><title><![CDATA[Reply to 2 Relay on PaHub on Thu, 04 Mar 2021 15:47:40 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/mad23" aria-label="Profile: mad23">@<bdi>mad23</bdi></a></p>
<p dir="auto">I'd say so, yes, but I don't have a Pb.Hub so I cannot say for sure, sorry.</p>
<p dir="auto">@all: maybe somebody who owns a Pb.Hub can help out here?</p>
]]></description><link>https://community.m5stack.com/post/12809</link><guid isPermaLink="true">https://community.m5stack.com/post/12809</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 04 Mar 2021 15:47:40 GMT</pubDate></item><item><title><![CDATA[Reply to 2 Relay on PaHub on Thu, 04 Mar 2021 15:34:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> said in <a href="/post/12796">2 Relay on PaHub</a>:</p>
<p dir="auto">Pa.Hub is an I2C extension hub so unless your relays use I2C (which I doubt) you cannot use a Pa.Hub to connect and switch two relays.<br />
Did you mean Pb.Hub?</p>
<p dir="auto">Would the PbHub be used for this application?</p>
]]></description><link>https://community.m5stack.com/post/12808</link><guid isPermaLink="true">https://community.m5stack.com/post/12808</guid><dc:creator><![CDATA[mad23]]></dc:creator><pubDate>Thu, 04 Mar 2021 15:34:51 GMT</pubDate></item><item><title><![CDATA[Reply to 2 Relay on PaHub on Thu, 04 Mar 2021 08:30:56 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/mad23" aria-label="Profile: mad23">@<bdi>mad23</bdi></a></p>
<p dir="auto">Pa.Hub is an I2C extension hub so unless your relays use I2C (which I doubt) you cannot use a Pa.Hub to connect and switch two relays.</p>
<p dir="auto">Did you mean P<strong>b</strong>.Hub?</p>
]]></description><link>https://community.m5stack.com/post/12796</link><guid isPermaLink="true">https://community.m5stack.com/post/12796</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 04 Mar 2021 08:30:56 GMT</pubDate></item></channel></rss>
