<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to erase M5Stick-C completely?]]></title><description><![CDATA[<h1>I have a M5Stick-C and played around with it a while. I flashed it with UI Flow 1.7.2 and tried to flash with 1.4.5 after that. It doesn't work I get the message that it doesn't have enough memory. Even the Sketch "Factory Test" isn't flashable using Arduino IDE: Not enough memory! I tried to erase the chip with M5Burner 2.2.4 and got the following message:</h1>
<h1>Erase now</h1>
<h1><a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v2.5.0<br />
Serial port /dev/tty.usbserial-FD51B432F3<br />
Connecting....<br />
Detecting chip type... ESP32<br />
Chip is ESP32-PICO-D4 (revision 1)<br />
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse<br />
MAC: 24:a1:60:54:44:dc<br />
Uploading stub...<br />
Running stub...<br />
Stub running...<br />
Erasing flash (this may take a while)...<br />
Chip erase completed successfully in 2.0s<br />
Hard resetting via RTS pin...</h1>
<h1>Erase Successfully</h1>
<p dir="auto">It seems to be ok but the result is as before. How can I erase the chip COMPLETELY?</p>
]]></description><link>https://community.m5stack.com/topic/3038/how-to-erase-m5stick-c-completely</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:36:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3038.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 Mar 2021 20:32:01 GMT</pubDate><ttl>60</ttl></channel></rss>
