<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to power M5Stack Core 2.]]></title><description><![CDATA[<p dir="auto">Hello everybody, I'm working in a project with this amazing MCU and I have one  question.<br />
The project consist in a system remotely programmable so I'm using the LAN module K012-B.<br />
As you know, this module have an addicional input supply. The question is the following. Can I power all the system by this way and if I need to reprogramming be able to connect the USB port ? The 2 at the same time. I look the schematic but I doesn't find any protective diode.<br />
Thank you.<br />
Rob</p>
]]></description><link>https://community.m5stack.com/topic/3075/how-to-power-m5stack-core-2</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 14:20:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3075.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Mar 2021 09:56:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to power M5Stack Core 2. on Fri, 12 Mar 2021 18:46:59 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/robertolo" aria-label="Profile: Robertolo">@<bdi>Robertolo</bdi></a></p>
<p dir="auto">if you look at the <a href="https://docs.m5stack.com/#/en/core/core2?id=schematic" target="_blank" rel="noopener noreferrer nofollow ugc">M5Core2 schematic</a> in the top left corner you'll find AXP192 and its inputs ACIN (connected to USB_5V) and VBUS (connected to BUS_5V). USB_5V comes from USB and BUS_5V comes from the LAN module.</p>
<p dir="auto">The AXP192 automatically switches between the available power sources and picks the one best suitable. Please also check the <a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/core/AXP192_datasheet_en.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">AXP192 datasheet</a>.</p>
]]></description><link>https://community.m5stack.com/post/12958</link><guid isPermaLink="true">https://community.m5stack.com/post/12958</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 12 Mar 2021 18:46:59 GMT</pubDate></item></channel></rss>
