<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Works with Chromebook?]]></title><description><![CDATA[<p dir="auto">I'm considering using UIFlow to teach microcontroller programming to high school students.  Many of them will be using Chromebooks.  Has the browser version of UIFlow been tested with Chromebook OS?</p>
]]></description><link>https://community.m5stack.com/topic/3100/works-with-chromebook</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:29:19 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3100.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Mar 2021 03:50:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Works with Chromebook? on Tue, 17 Jan 2023 15:09:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> Hey everyone! First post here. Is the full support problem regarding Chrome OS solved? I would like to know if I could flash a M5Stick CPlus on a Chromebook or not. As far as I've read, I can program one via browserbased UIFlow on Chromebooks only...</p>
]]></description><link>https://community.m5stack.com/post/19896</link><guid isPermaLink="true">https://community.m5stack.com/post/19896</guid><dc:creator><![CDATA[coffee99]]></dc:creator><pubDate>Tue, 17 Jan 2023 15:09:59 GMT</pubDate></item><item><title><![CDATA[Reply to Works with Chromebook? on Tue, 18 May 2021 03:53:56 GMT]]></title><description><![CDATA[<p dir="auto">Thanks very much!  A simple workaround me is to use m5burner on a separate non-chrome machine to load the firmware, and then have the students upload programs via wifi connection.  Thanks!</p>
]]></description><link>https://community.m5stack.com/post/13811</link><guid isPermaLink="true">https://community.m5stack.com/post/13811</guid><dc:creator><![CDATA[chrismoraes]]></dc:creator><pubDate>Tue, 18 May 2021 03:53:56 GMT</pubDate></item><item><title><![CDATA[Reply to Works with Chromebook? on Fri, 19 Mar 2021 03:50:18 GMT]]></title><description><![CDATA[<p dir="auto">our engineer is work on the chrome OS compatible problem. so before we fixed it,  we still suggest you use win10/MacOS/ubuntu.  thank you</p>
]]></description><link>https://community.m5stack.com/post/13120</link><guid isPermaLink="true">https://community.m5stack.com/post/13120</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 19 Mar 2021 03:50:18 GMT</pubDate></item><item><title><![CDATA[Reply to Works with Chromebook? on Fri, 19 Mar 2021 02:52:56 GMT]]></title><description><![CDATA[<p dir="auto">And i just tested with the offline UIFLOW Desktp IDE with an intel based Chromebook and it works on linux beta.<br />
You only need to install libnss3</p>
]]></description><link>https://community.m5stack.com/post/13117</link><guid isPermaLink="true">https://community.m5stack.com/post/13117</guid><dc:creator><![CDATA[BricoMS]]></dc:creator><pubDate>Fri, 19 Mar 2021 02:52:56 GMT</pubDate></item><item><title><![CDATA[Reply to Works with Chromebook? on Fri, 19 Mar 2021 02:38:59 GMT]]></title><description><![CDATA[<p dir="auto">Yes! the browser version of UIflow (web/cloud) does work on my chromebook.</p>
<p dir="auto">What you might experience problems is with the m5burner.<br />
If you have intel based chromebooks you will be able to run it on crostini/linux beta.</p>
]]></description><link>https://community.m5stack.com/post/13116</link><guid isPermaLink="true">https://community.m5stack.com/post/13116</guid><dc:creator><![CDATA[BricoMS]]></dc:creator><pubDate>Fri, 19 Mar 2021 02:38:59 GMT</pubDate></item></channel></rss>
