<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Units CO2&#x2F;TVOC]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I'm trying the Units CO2/TVOC M5Stack Sick C.</p>
<p dir="auto">I'm just copy/pasting the code from the demo <a href="https://docs.m5stack.com/#/en/unit/tvoc" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/unit/tvoc</a><br />
And<br />
eCO2 stays blocked  =  400ppm<br />
TVOC stay bloced at 0<br />
H2 moving a bit around 13580</p>
<p dir="auto">Any idea ?<br />
Does not seems to work fine.... I have another device Neatmo measuring CO2. It says it's not 400 but almost 1300ppm</p>
<p dir="auto">COuld you help?<br />
thanks,</p>
]]></description><link>https://community.m5stack.com/topic/3103/units-co2-tvoc</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:12:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3103.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Mar 2021 22:38:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Units CO2&#x2F;TVOC on Sat, 12 Jun 2021 21:29:07 GMT]]></title><description><![CDATA[<p dir="auto">hi,<br />
don't know why but if you set that line n°31 in comment, it seems to work</p>
<p dir="auto">"# tvoc0.set_iaq_baseline(35187, 35502)<br />
while True:</p>
<p dir="auto">you may try to use the sample loop that you find in  UIflow_Unit TVOC.</p>
<p dir="auto">As you can see on the picture below, TOVC/eCO2 can be use in a classroom context and it works fine<br />
I initialized it outside the window and came inside after</p>
<p dir="auto"><img src="/assets/uploads/files/1623533102839-mesures5-resized.png" alt="0_1623533101105_Mesures5.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/14086</link><guid isPermaLink="true">https://community.m5stack.com/post/14086</guid><dc:creator><![CDATA[Serge]]></dc:creator><pubDate>Sat, 12 Jun 2021 21:29:07 GMT</pubDate></item><item><title><![CDATA[Reply to Units CO2&#x2F;TVOC on Sat, 20 Mar 2021 00:11:51 GMT]]></title><description><![CDATA[<p dir="auto">You need to find the right calibration (baseline) values for your unit, so only initialize it, but do not define a baseline, then you will see a difference. Also it should be clean air in the room, f.e. not smoking with closed windows for days.</p>
<p dir="auto">for debugging purpose output the current baseline values as well, I think you will see a big difference to the ones in the sample then.</p>
]]></description><link>https://community.m5stack.com/post/13155</link><guid isPermaLink="true">https://community.m5stack.com/post/13155</guid><dc:creator><![CDATA[mauwii]]></dc:creator><pubDate>Sat, 20 Mar 2021 00:11:51 GMT</pubDate></item></channel></rss>
