<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Updated version,  working Core2 web radio player, M5Stack]]></title><description><![CDATA[<p dir="auto">Re: [CORE2 as Web radio](without extra hardware ?)</p>
<p dir="auto">I made a few GUI changes, and checked into the library used for the decoding.</p>
<p dir="auto">I think it's worth noting that the actual library for the functions came from:<br />
Earle Philhower III<br />
Who credits his library in part to :  StellaPlayer and libMAD<br />
<a href="https://github.com/earlephilhower/ESP8266Audio" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/earlephilhower/ESP8266Audio</a></p>
<p dir="auto">Looking through the library so far I can not tell if there is extra information extracted from the stream that we can make use of.</p>
<p dir="auto">Here is the latest code:</p>
<pre><code>/*
   March 28, 2021
   Made changes to the Example Core2 Web Radio Player from:
   https://www.hackster.io/tommyho/arduino-web-radio-player-c4cb23
    Wish List:
    slightly organized the code into better sections (Done)
    Nicer Fonts (Done)
    Use 2nd CPU Core to handle GUI and button's so we keep it responsive
    Add bluetooth output to Bluetooth speakers / headest
    Get more information from the stream,  Album art, etc.
      --  Checked into what comes into the stream So far I don't see extra data
    Get track length and have a progress bar for the track
      -- Again I don't see if this information comes in from the library
    Have an interface to select WiFi network and enter password
    -- Store password in EEPROM
    Better mehod of selecting stations
    ? Maybe web interface for setting up station lists?
    I see that the actual library for the functions came from:
    Earle Philhower III
    Who credits his library to :  StellaPlayer and libMAD
//  m5StreamTest Version 2020.12b (Source/Buffer Tester)
//  Board: M5StackCore2 (esp32)
//  Author: tommyho510@gmail.com
//  Required: Arduino library ESP8266Audio 1.60
#include &lt;M5Core2.h&gt;
#include &lt;driver/i2s.h&gt;
#include &lt;WiFi.h&gt;
#include &lt;AudioFileSourceICYStream.h&gt;
#include &lt;AudioFileSource.h&gt;
#include &lt;AudioFileSourceBuffer.h&gt;
#include &lt;AudioFileSourceSPIRAMBuffer.h&gt;
#include &lt;AudioGeneratorMP3.h&gt;
#include &lt;AudioOutputI2S.h&gt;
#include "Free_Fonts.h"
//#include &lt;spiram-fast.h&gt;
const int bufferSize = 128 * 1024; // buffer size in byte
// Enter your WiFi, Station, button settings here:
const char *SSID = "ENTER_SSID_HERE";
const char *PASSWORD = "ENTER_WIFI_PASSWORD_HERE";
// Added Charlie FM in Portland Oregon
//http://24083.live.streamtheworld.com:80/KYCHFM_SC
//Removed these from the list:
//  {"Mega Shuffle", "http://jenny.torontocast.com:8134/stream"},
//  {"Way Up Radio", "http://188.165.212.154:8478/stream"},
//  {"Asia Dream", "https://igor.torontocast.com:1025/;.-mp3"},
//  {"KPop Way Radio", "http://streamer.radio.co/s06b196587/listen"},
//  {"SomaFM", "http://ice2.somafm.com/christmas-128-mp3"}
const int stations = 7;// Change Number here if you add feeds!
char * stationList[stations][2] = {
  {"Charlie FM", "http://24083.live.streamtheworld.com:80/KYCHFM_SC"},
  {"MAXXED Out", "http://149.56.195.94:8015/steam"},
  {"Orig. Top 40", "http://ais-edge09-live365-dal02.cdnstream.com/a25710"},
  {"Smooth Jazz", "http://sj32.hnux.com/stream?type=http&amp;nocache=3104"},
  {"Smooth Lounge", "http://sl32.hnux.com/stream?type=http&amp;nocache=1257"},
  {"Classic FM", "http://media-ice.musicradio.com:80/ClassicFMMP3"},
  {"Lite Favorites", "http://naxos.cdnstream.com:80/1255_128"}
float audioGain = 0.0;
float gainfactor = 0.08;
int currentStationNumber = 0;
unsigned long disUpdate = millis();
AudioGeneratorMP3 *mp3;
AudioFileSourceICYStream *filemp3;
AudioFileSourceBuffer *buffmp3;
AudioOutputI2S *out, *outmp3;
// Draw a + mark centred on x,y
void drawDatumMarker(int x, int y)
  M5.Lcd.drawLine(x - 5, y, x + 5, y, TFT_GREEN);
  M5.Lcd.drawLine(x, y - 5, x, y + 5, TFT_GREEN);
/// WIFI Routines *********************
void initwifi() {
  M5.Lcd.setTextColor(TFT_BLUE, TFT_BLACK);
  M5.Lcd.setTextSize(2);
  M5.Lcd.setTextDatum(BC_DATUM);
  M5.Lcd.setFreeFont(FSB12);
  M5.Lcd.drawString("Connecting..", M5.Lcd.width()/2, 200, GFXFF);
  WiFi.disconnect();
  WiFi.softAPdisconnect(true);
  WiFi.mode(WIFI_STA);
  WiFi.begin(SSID, PASSWORD);
  // Try forever
  int i = 0;
  while (WiFi.status() != WL_CONNECTED) {
    Serial.print("STATUS(Connecting to WiFi) ");
    delay(1500);
    i = i + 1;
    if (i &gt; 15) {
      ESP.restart();
  Serial.println("\nWiFi Connected!\n");
// Display network information on the LCD
void displayWiFiInformation() {
  M5.Lcd.setTextColor(TFT_WHITE, TFT_BLACK);
  M5.Lcd.setTextSize(1);
  M5.Lcd.setFreeFont(FSS9);
  M5.Lcd.setTextDatum(BL_DATUM);
  M5.Lcd.drawString("Network: ", 10, 165, GFXFF);
  M5.Lcd.drawString("IP: " , 10, 190, GFXFF);
  M5.Lcd.drawString(SSID, 90, 165, GFXFF);
  M5.Lcd.drawString(WiFi.localIP().toString(),40,190,GFXFF);
// Update WiFi Signal Strength
void updateWiFiSignal() {
  // Display the WiFi Signal Strength
  M5.Lcd.drawString("WiFi Signal: ", 10, 215, GFXFF);
  M5.Lcd.fillRect(112,195,30,20,BLACK);
  uint16_t clr = GREEN;
  clr = (WiFi.RSSI() &lt; -70) ? TFT_RED : TFT_GREEN;
  M5.Lcd.setTextColor(clr, TFT_BLACK);
  M5.Lcd.drawString(String(WiFi.RSSI()),115, 215, GFXFF);
/// Battery ***************************
// Calculate Battery Useable range  (3.2 to 4.1 Volts)
void displayBattery() {
  int maxVolts = 410;  // Battery Max volts * 100
  int minVolts = 320;  // Battery Min Volts * 100
  char battInfo[5];
  dtostrf(M5.Axp.GetBatVoltage(),1,2,battInfo);
  String btInfo = "Batt: " + String(battInfo);
  M5.Lcd.drawString(btInfo, 230, 215, GFXFF);
//  drawDatumMarker(230,215);
  int batt = map(M5.Axp.GetBatVoltage() * 100, minVolts, maxVolts, 0 , 10000) / 100.0;
  // Draw Battery bar(s) on the right side of the screen
  for (int x = 9; x &gt;= 0; x--) {
    if (x &lt; 3) clr = RED;
    else if (x &lt; 6) clr = YELLOW;
    M5.Lcd.fillRoundRect(314, (216 - (x * 24)), 6, 21, 2, (batt &gt; (x * 10)) ? clr : BLACK);
    M5.Lcd.drawRoundRect(314, (216 - (x * 24)), 6, 21, 2, TFT_LIGHTGREY);
// MISC  ****************************
// Remove the Track information (While changing stations)
void clearTrack() {
  M5.Lcd.fillRect(10, 55, 300, 70, TFT_DARKGREY); // Clear the area of old data
  M5.Lcd.drawRect(10, 55, 300, 70, BLUE); // Draw a box around the Track Information
// Identify buttons at the bottom of screen
void drawButtons() {
  M5.Lcd.fillRect(10,220,300,25,YELLOW);
  M5.Lcd.setTextColor(TFT_BLACK);
  M5.Lcd.setTextDatum(TC_DATUM);
  M5.Lcd.drawString("Volume", 55,220, GFXFF);
  M5.Lcd.drawString("Station", M5.Lcd.width()/2,220, GFXFF);
  M5.Lcd.drawString("Mute", 270 ,220, GFXFF);
// Get the Split String Value Used for Band or Track
String getValue(String data, char separator, int index) {
  int found = 0;
  int strIndex[] = {0, -1};
  int maxIndex = data.length() - 1;
  for (int i = 0; i &lt;= maxIndex &amp;&amp; found &lt;= index; i++) {
    if (data.charAt(i) == separator || i == maxIndex) {
      found++;
      strIndex[0] = strIndex[1] + 1;
      strIndex[1] = (i == maxIndex) ? i + 1 : i;
  return found &gt; index ? data.substring(strIndex[0], strIndex[1]) : "";
// MP3, Audio etc.  ****************************
// Called when a metadata event occurs (i.e. an ID3 tag, an ICY block, etc.
void MDCallback(void *cbData, const char *type, bool isUnicode, const char *string) {
  const char *ptr = reinterpret_cast&lt;const char *&gt;(cbData);
  (void) isUnicode; // Punt this ball for now
  // Note that the type and string may be in PROGMEM, so copy them to RAM for printf
  char s1[32], s2[64];
  strncpy_P(s1, type, sizeof(s1));
  s1[sizeof(s1) - 1] = 0;
  strncpy_P(s2, string, sizeof(s2));
  s2[sizeof(s2) - 1] = 0;
  String band  = getValue(s2, '-', 0);
  band.trim();
  String track = getValue(s2, '-', 1);
  track.trim();
  if(band.length() &gt; 30) band = band.substring(0, 30);
  if(track.length() &gt; 30) track = track.substring(0, 30);
//  Serial.printf("Band: %s   Track:  %s  \n", band.c_str(), track.c_str());
  Serial.printf("METADATA(%s) '%s' = '%s'\n", ptr, s1, s2);
  M5.Lcd.setTextColor(TFT_BLACK, TFT_DARKGREY );
  clearTrack();
  M5.Lcd.setTextDatum(MC_DATUM);
  if(band.length() &lt; 20) M5.Lcd.setFreeFont(FSS12);                              // Select the font
  M5.Lcd.drawString(band, M5.Lcd.width()/2, 72, GFXFF);
  if(track.length() &lt; 20) M5.Lcd.setFreeFont(FSS12);
//  M5.Lcd.setTextDatum(MC_DATUM);
  M5.Lcd.drawString(track, M5.Lcd.width()/2, 107, GFXFF);
  Serial.flush();
  // Make sure the new song information does not overwrite the battery
  displayBattery();
// Called when there's a warning or error (like a buffer underflow or decode hiccup)
void StatusCallback(void *cbData, int code, const char *string) {
  // Note that the string may be in PROGMEM, so copy it to RAM for printf
  char s1[64];
  strncpy_P(s1, string, sizeof(s1));
  Serial.printf("STATUS(%s) '%d' = '%s'\n", ptr, code, s1);
  Serial.flush();
void stopPlaying() {
  Serial.printf("Stopping MP3...\n");
  if (mp3) {
    mp3-&gt;stop();
    delete mp3;
    mp3 = NULL;
  Serial.printf("MP3 Stopped, Stopping Buffer...\n");
  if (buffmp3) {
    buffmp3-&gt;close();
    delete buffmp3;
    buffmp3 = NULL;
  Serial.printf("Buffer stopped... Stopping File ...\n");
  if (filemp3) {
    filemp3-&gt;close();
    delete filemp3;
    filemp3 = NULL;
  if (outmp3) {
    //    filemp3-&gt;close();
    delete outmp3;
    outmp3 = NULL;
  Serial.printf("STATUS(Stopped)\n");
  Serial.flush();
// Update the Station Label
void updateStation(String message) {
  M5.Lcd.fillRect(10, 10, 300, 35, BLACK); // Clear out other information on the line
  M5.Lcd.setTextColor(TFT_GREEN, TFT_BLACK);
  M5.Lcd.setFreeFont(FSB18);
  M5.Lcd.drawString(message, M5.Lcd.width()/2, 10, GFXFF);
// Change to the next station
void changeStation() {
  updateStation("Changing..Wait..");
  currentStationNumber++;
  if (currentStationNumber &gt;= stations) currentStationNumber = 0;
  Serial.printf("\n******** Changing to channel number: %i\n", currentStationNumber);
// Change the volume level
// Update the volume graphic
void changeVolume() {
  audioGain += 1.0;
  if (audioGain &gt; 10.0) {
    audioGain = 1.0;
  if (audioGain &lt; 0.0) {
    audioGain = 0.0;
  int xtPos = 260; // X Position for the Volume indication
  outmp3-&gt;SetGain(audioGain * gainfactor); // Change Volume to new level
//---------New Volume Bar on left side of LCD  *******************
  // Draw Volume bar(s) on the left side of the screen
  uint16_t clr = RED;
    if (x &lt; 5) clr = GREEN;
    else if (x &lt; 8) clr = TFT_ORANGE;
    M5.Lcd.fillRoundRect(0, (216 - (x * 24)), 6, 21, 2, (audioGain &gt; x ) ? clr : BLACK);
    M5.Lcd.drawRoundRect(0, (216 - (x * 24)), 6, 21, 2, TFT_LIGHTGREY);
  // Alternate Draw the Volume Indicator (Triangle)
//  M5.Lcd.fillTriangle(xtPos, 20, xtPos + 50, 20, xtPos + 50, 0, BLACK); // Clear out old Meter
//  if (audioGain &gt; 9) { // If we are full, draw red, blue and green
//    M5.Lcd.fillTriangle(xtPos, 20, xtPos + (5 * audioGain), 20, xtPos + (5 * audioGain), 20 - (2 * audioGain), RED);
//    M5.Lcd.fillTriangle(xtPos, 20, xtPos + (5 * 9), 20, xtPos + (5 * 9), 20 - (2 * 9), BLUE);
//    M5.Lcd.fillTriangle(xtPos, 20, xtPos + (5 * 6), 20, xtPos + (5 * 6), 20 - (2 * 6), GREEN);
//  else if (audioGain &gt;= 6) { // if above 5, draw blue and green
//    M5.Lcd.fillTriangle(xtPos, 20, xtPos + (5 * audioGain), 20, xtPos + (5 * audioGain), 20 - (2 * audioGain), BLUE);
//  else if (audioGain &gt;= 1)
//    M5.Lcd.fillTriangle(xtPos, 20, xtPos + (5 * audioGain), 20, xtPos + (5 * audioGain), 20 - (2 * audioGain), GREEN);
   Setup output to I2S Device
   Set Pins and Gain
   Set FileSource as web radio station
   Join FileSource to get MetaData
   Create Buffer for data
   Register Callback for...?
   Begin the MP3 playback
void playMP3() {
  outmp3 = new AudioOutputI2S(0, 0); // Output to builtInDAC
  outmp3-&gt;SetPinout(12, 0, 2);
  outmp3-&gt;SetOutputModeMono(true);
  filemp3 = new AudioFileSourceICYStream(stationList[currentStationNumber][1]);
  filemp3-&gt;RegisterMetadataCB(MDCallback, (void*)"ICY"); // ID3TAG  // ICY
  // StreamTitle
  buffmp3 = new AudioFileSourceBuffer(filemp3, bufferSize);
  buffmp3-&gt;RegisterStatusCB(StatusCallback, (void*)"buffer");
  mp3 = new AudioGeneratorMP3();
  mp3-&gt;RegisterStatusCB(StatusCallback, (void*)"mp3");
  mp3-&gt;begin(buffmp3, outmp3);
  Serial.printf("STATUS(URL) %s %s\n", stationList[currentStationNumber][0], stationList[currentStationNumber][1]);
  Serial.flush();
  updateStation(String(stationList[currentStationNumber][0]));
void loopMP3() {
  if (mp3 != NULL) {  // To avoid crash while changing stationsI
    if (mp3-&gt;isRunning()) {
      if (!mp3-&gt;loop()) mp3-&gt;stop();
    } else {
      Serial.printf("Status(Stream) Stopped \n");
      clearTrack();
      changeStation();
      //      stopPlaying();
      delay(1000);
      playMP3();
// General Arduino Routines
  Serial.begin(115200);
  M5.begin();
  M5.Axp.SetSpkEnable(true);
  //  M5.Lcd.setRotation(3);
  M5.Lcd.fillScreen(BLACK);
  M5.Lcd.setTextWrap(false);
  M5.Lcd.drawString("Core2 Web Radio", M5.Lcd.width()/2, 20, GFXFF);
  initwifi();
  delay(500);
  M5.Lcd.clear();
  drawButtons();
  playMP3();
  changeVolume();  // To update Volume setting and graphic
  displayWiFiInformation();
  loopMP3();
  M5.update();
  if (m5.BtnA.wasPressed()) { //Change Volume(Button A)
    changeVolume();
  if (m5.BtnB.wasPressed()) { //Change Station(Button B)
    clearTrack();
    changeStation();
    stopPlaying();
    playMP3();
  if (m5.BtnC.wasPressed()) { //Mute  (Button C)
    audioGain = -1.0;
    changeVolume();
  // Update the battery voltage, and WiFi Signal every second
  if ((disUpdate + 1000) &lt; millis()) {
    displayBattery();
    updateWiFiSignal();
<p dir="auto">But this is a slightly nicer interface.</p>
]]></description><link>https://community.m5stack.com/topic/3128/updated-version-working-core2-web-radio-player-m5stack</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:13:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3128.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Mar 2021 16:13:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Tue, 11 Feb 2025 08:16:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/perlix" aria-label="Profile: perlix">@<bdi>perlix</bdi></a><br />
Hi, are you sure to remove the line 'Serial.begin(115200);' in setup() and not change it to 'Serial.begin(9600);' or something else? I remove this line and compile it , a lot of error occured. Any advise. Thank you.</p>
]]></description><link>https://community.m5stack.com/post/28173</link><guid isPermaLink="true">https://community.m5stack.com/post/28173</guid><dc:creator><![CDATA[wmlooi]]></dc:creator><pubDate>Tue, 11 Feb 2025 08:16:50 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Tue, 11 Feb 2025 08:07:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I'm just bought the Core2 v1.1 and having a problem that "Changing..Wait.." state always running for the below links. Non of the links can be played. I'm using VLC to verify the streaming links no issue, all links are playable.</p>
<p dir="auto">const int stations = 7;// Change Number here if you add feeds!<br />
char * stationList[stations][2] = {<br />
//  {"Guangzhou MYFM 88.0", "<a href="https://lhttp.qingting.fm/live/20194/64k.mp3" target="_blank" rel="noopener noreferrer nofollow ugc">https://lhttp.qingting.fm/live/20194/64k.mp3</a>"},<br />
//  {"8FM", "<a href="https://mediaprima.rastream.com/mediaprima-onefm" target="_blank" rel="noopener noreferrer nofollow ugc">https://mediaprima.rastream.com/mediaprima-onefm</a>"},<br />
//  {"988 FM", "<a href="https://playerservices.streamtheworld.com/pls/988_FM.pls" target="_blank" rel="noopener noreferrer nofollow ugc">https://playerservices.streamtheworld.com/pls/988_FM.pls</a>"},<br />
//  {"Ai FM", "<a href="https://playerservices.streamtheworld.com/pls/AI_FM.pls" target="_blank" rel="noopener noreferrer nofollow ugc">https://playerservices.streamtheworld.com/pls/AI_FM.pls</a>"},<br />
//  {"GoXuan", "<a href="https://stream-eu-a.rcs.revma.com/xt9nhzsbv4uvv/7_1kpxic2j08fx102/playlist.m3u8" target="_blank" rel="noopener noreferrer nofollow ugc">https://stream-eu-a.rcs.revma.com/xt9nhzsbv4uvv/7_1kpxic2j08fx102/playlist.m3u8</a>"},<br />
// {"Melody", "<a href="https://stream-eu-a.rcs.revma.com/2u1n6dtbv4uvv/7_w0cr3cmmz25o02/playlist.m3u8" target="_blank" rel="noopener noreferrer nofollow ugc">https://stream-eu-a.rcs.revma.com/2u1n6dtbv4uvv/7_w0cr3cmmz25o02/playlist.m3u8</a>"},<br />
//  {"MY", "<a href="https://stream-eu-a.rcs.revma.com/hc3unrtbv4uvv/56_1t996oveblvvv02/playlist.m3u8" target="_blank" rel="noopener noreferrer nofollow ugc">https://stream-eu-a.rcs.revma.com/hc3unrtbv4uvv/56_1t996oveblvvv02/playlist.m3u8</a>"}<br />
};</p>
<p dir="auto">But, I tried the <a class="plugin-mentions-user plugin-mentions-a" href="/user/nerdlogger" aria-label="Profile: nerdlogger">@<bdi>nerdlogger</bdi></a> streaming links no problem. The links are playable. Any advise? Thank you.</p>
]]></description><link>https://community.m5stack.com/post/28172</link><guid isPermaLink="true">https://community.m5stack.com/post/28172</guid><dc:creator><![CDATA[wmlooi]]></dc:creator><pubDate>Tue, 11 Feb 2025 08:07:58 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sun, 14 Jan 2024 17:30:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nerdlogger" aria-label="Profile: nerdlogger">@<bdi>nerdlogger</bdi></a> Thank you so much for passing this along! I haven't done much with this in the last year, so forgot where I was at with it, but it will be nice to formally fix the problem as listed in that discussion.</p>
<p dir="auto">As an aside, I did have to get a new Core2 from Mouser (after discussion with M5Stack, who paid for the replacement), because my display on first Core2 started 'fogging up' / going bad around the edges. I had left it on for a while, so not sure if that was related. Anyhow, it makes me wonder about the display quality on these. I had attempted to help M5Stack out as best I could by providing the serial # of bad unit, but I had finally tossed my box a few weeks before this happened. The serial # is not embedded in any of the M5Stack memory/firmware, so that's unfortunate for them. It's only on the box it arrives in.</p>
<p dir="auto">Finally, I realize the fun of programming a Core2 or other development board with whatever a programmer wants to do with it (which is why we buy these!), but for somebody who wants a pure streaming internet radio player that pretty much embodies what a person could eventually turn a Core2 into, check out the Yoto Player or Yoto Mini player. It is designed for children, but uses RFID cards that are inserted on top. Point is that you can program radio station URLs onto a card and select whatever station you want. Custom icons on small display, great speaker(s), excellent WIFI connectivity, and great battery life. I own both of those (well, my children do!) and can attest to the great ability as a streaming radio player. This performance is much better than portable offerings from Sangean, Lemega, Ocean Digital, etc.</p>
<p dir="auto">Thanks again!</p>
]]></description><link>https://community.m5stack.com/post/23345</link><guid isPermaLink="true">https://community.m5stack.com/post/23345</guid><dc:creator><![CDATA[analog_man]]></dc:creator><pubDate>Sun, 14 Jan 2024 17:30:25 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sat, 13 Jan 2024 03:13:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/analog_man" aria-label="Profile: analog_man">@<bdi>analog_man</bdi></a> I know this is more than a year old, but maybe you'll see it (or someone else will). I just installed the player code on my core2 device. I grabbed the github version. I have M5Core2 version 0.1.8 installed and initially I had the exact same issues you're describing. The two stations that worked sounded like they were playing at  half or quarter speed.</p>
<p dir="auto">See here for discussion: <a href="https://github.com/m5stack/M5Core2/issues/110" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Core2/issues/110</a></p>
<p dir="auto">The short of it:</p>
<p dir="auto">replace "M5.begin();" in setup() with "M5.begin(true, true, true, true, kMBusModeOutput, false); ".......</p>
<p dir="auto">Pretty much perfect playback. I use the following links:</p>
<p dir="auto">const int stations = 9;// Change Number here if you add feeds!<br />
{"Orig. Top 40", "<a href="http://ais-edge09-live365-dal02.cdnstream.com/a25710" target="_blank" rel="noopener noreferrer nofollow ugc">http://ais-edge09-live365-dal02.cdnstream.com/a25710</a>"},<br />
{"Lite Favorites", "<a href="http://naxos.cdnstream.com:80/1255_128" target="_blank" rel="noopener noreferrer nofollow ugc">http://naxos.cdnstream.com:80/1255_128</a>"},<br />
{"ORF O3", "<a href="http://ors-sn02.ors-shoutcast.at/oe3-q2a" target="_blank" rel="noopener noreferrer nofollow ugc">http://ors-sn02.ors-shoutcast.at/oe3-q2a</a>"},<br />
{"ORF Salzburg", "<a href="http://ors-sn07.ors-shoutcast.at/sbg-q2a" target="_blank" rel="noopener noreferrer nofollow ugc">http://ors-sn07.ors-shoutcast.at/sbg-q2a</a>"},<br />
{"CBC Music #1", "<a href="http://26423.live.streamtheworld.com/CBLFM_CBC_SC" target="_blank" rel="noopener noreferrer nofollow ugc">http://26423.live.streamtheworld.com/CBLFM_CBC_SC</a>"},<br />
//{"CBC Music #2", "<a href="http://19003.live.streamtheworld.com/CBLFM_CBC_SC" target="_blank" rel="noopener noreferrer nofollow ugc">http://19003.live.streamtheworld.com/CBLFM_CBC_SC</a>"},<br />
//{"CBC Music #3", "<a href="http://18063.live.streamtheworld.com/CBLFM_CBC_SC" target="_blank" rel="noopener noreferrer nofollow ugc">http://18063.live.streamtheworld.com/CBLFM_CBC_SC</a>"},<br />
{"WETA Classical #1", "<a href="http://17643.live.streamtheworld.com/WETAFM_SC" target="_blank" rel="noopener noreferrer nofollow ugc">http://17643.live.streamtheworld.com/WETAFM_SC</a>"},<br />
//{"WETA Classical #2", "<a href="http://26103.live.streamtheworld.com/WETAFM_SC" target="_blank" rel="noopener noreferrer nofollow ugc">http://26103.live.streamtheworld.com/WETAFM_SC</a>"},<br />
//{"WETA Classical #3", "<a href="http://26153.live.streamtheworld.com/WETAFM_SC" target="_blank" rel="noopener noreferrer nofollow ugc">http://26153.live.streamtheworld.com/WETAFM_SC</a>"},<br />
//{"Classic FM", "<a href="http://media-ice.musicradio.com:80/ClassicFMMP3" target="_blank" rel="noopener noreferrer nofollow ugc">http://media-ice.musicradio.com:80/ClassicFMMP3</a>"},<br />
{"Radio Classique", "<a href="http://radioclassique.ice.infomaniak.ch/radioclassique-high.mp3" target="_blank" rel="noopener noreferrer nofollow ugc">http://radioclassique.ice.infomaniak.ch/radioclassique-high.mp3</a>"},<br />
{"Concertgebouw Live", "<a href="http://i1.cdn.jetstre.am:8000/sz=RCOLiveWebradio=mp3-192" target="_blank" rel="noopener noreferrer nofollow ugc">http://i1.cdn.jetstre.am:8000/sz=RCOLiveWebradio=mp3-192</a>"}<br />
};</p>
<p dir="auto">I'm right now listening to these and they all work like a charm. Even the 192Kb/s RCO Live (Concertgebouw Live) works. You can check the stream links in VLC to make sure.</p>
<p dir="auto">Hope this helps.....</p>
]]></description><link>https://community.m5stack.com/post/23321</link><guid isPermaLink="true">https://community.m5stack.com/post/23321</guid><dc:creator><![CDATA[nerdlogger]]></dc:creator><pubDate>Sat, 13 Jan 2024 03:13:13 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sat, 12 Nov 2022 20:45:25 GMT]]></title><description><![CDATA[<p dir="auto">Before I get too involved uploading code or showing library versions I'm using, can anyone else on this thread verify whether their Core2 player still streams correctly?</p>
<p dir="auto">I bought a new Core2 last week and was happy to find bwbguard's code. I removed some of the stations that don't exist anymore, but left in these three:</p>
<p dir="auto">{"Orig. Top 40", "<a href="http://ais-edge09-live365-dal02.cdnstream.com/a25710" target="_blank" rel="noopener noreferrer nofollow ugc">http://ais-edge09-live365-dal02.cdnstream.com/a25710</a>"},<br />
{"Lite Favorites", "<a href="http://naxos.cdnstream.com:80/1255_128" target="_blank" rel="noopener noreferrer nofollow ugc">http://naxos.cdnstream.com:80/1255_128</a>"}</p>
<p dir="auto">The Classic FM sounds decent, but the other two are greatly distorted and sound like they're playing at 1/4 or 1/2 rate or so. I have tried other MP3 url's, and those sound distorted too so it definitely seems the norm and not the exception.</p>
<p dir="auto">VLC showed me the bit rates of the 3 above are 128 kb/s, 32 bits/sample, 44.1 kHz sample rate.</p>
<p dir="auto">What's more, this Core2 web player seems to change stations on its own sometimes and occasionally restart.</p>
<p dir="auto">This happens with latest ESP8266Audio 1.9.7 library, but I have tried previous as well. I'm using 0.1.4 M5Stack_Core2 library.</p>
<p dir="auto">I read this thread and tried toggling the PSRAM enable, and tried the Core2 board from M5stack as well as ESP32, but the one from ESP32 would not compile.I've tried 160 and 240 MHz which makes no difference.</p>
<p dir="auto">I even tried the code from this thread, the 'original' thread, and the code from bwbguard's github site.</p>
<p dir="auto">Can anyone offer some suggestions?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://community.m5stack.com/post/19281</link><guid isPermaLink="true">https://community.m5stack.com/post/19281</guid><dc:creator><![CDATA[analog_man]]></dc:creator><pubDate>Sat, 12 Nov 2022 20:45:25 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sun, 09 Jan 2022 23:08:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jdonth" aria-label="Profile: jdonth">@<bdi>jdonth</bdi></a> Had the exact same problem.........after 3 hours of googling, finally found the issue. Take a look at this diff file:</p>
<p dir="auto"><a href="https://git.koehlerweb.org/frodovdr/Sonoff-Tasmota/commit/8a764f86ee9f1129507f4654d07c7a7cb24cc87e" target="_blank" rel="noopener noreferrer nofollow ugc">https://git.koehlerweb.org/frodovdr/Sonoff-Tasmota/commit/8a764f86ee9f1129507f4654d07c7a7cb24cc87e</a></p>
<p dir="auto">It's totally unrelated to this project. Just a bug that freaks out the IDE. Anyhow......a couple of lines need to be changed in :</p>
<p dir="auto">\libraries\ESP8266Audio\src\libtinysoundfont\tsf.h</p>
<p dir="auto">Hopefully it makes sense......Hope it helps....</p>
]]></description><link>https://community.m5stack.com/post/16129</link><guid isPermaLink="true">https://community.m5stack.com/post/16129</guid><dc:creator><![CDATA[nerdlogger]]></dc:creator><pubDate>Sun, 09 Jan 2022 23:08:16 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Thu, 30 Dec 2021 17:42:09 GMT]]></title><description><![CDATA[<p dir="auto">Attempting to compile the web radio player on a Core2. I am getting the following errors. Any help would be appreciated.<br />
Joe</p>
<p dir="auto">Arduino: 1.8.19 (Windows 10), Board: "M5Stack-Core2, Enabled, Default (2 x 6.5 MB app, 3.6 MB SPIFFS), 240MHz (WiFi/BT), 1500000, None"</p>
<p dir="auto">C:\Users\jld\Documents\Arduino\MediaPlayer\MediaPlayer.ino:61:1: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]</p>
<p dir="auto">};</p>
<p dir="auto">^</p>
<p dir="auto">In file included from C:\Users\jld\Documents\Arduino\libraries\ESP8266Audio\src\AudioGeneratorMIDI.cpp:65:</p>
<p dir="auto">C:\Users\jld\Documents\Arduino\libraries\ESP8266Audio\src\libtinysoundfont/tsf.h: In function 'void tsf_channel_midi_control(tsf*, int, int, int)':</p>
<p dir="auto">C:\Users\jld\Documents\Arduino\libraries\ESP8266Audio\src\libtinysoundfont/tsf.h:2100:1: error: insn does not satisfy its constraints:</p>
<p dir="auto">}</p>
<p dir="auto">^</p>
<p dir="auto">(insn 858 343 344 51 (set (reg:SF 19 f0 [407])</p>
<p dir="auto">(mem/u/c:SF (symbol_ref/u:SI ("*.LC248") [flags 0x2]) [0  S4 A32])) "C:\Users\jld\Documents\Arduino\libraries\ESP8266Audio\src\libtinysoundfont/tsf.h":2053 47 {movsf_internal}</p>
<p dir="auto">(nil))</p>
<p dir="auto">during RTL pass: postreload</p>
<p dir="auto">C:\Users\jld\Documents\Arduino\libraries\ESP8266Audio\src\libtinysoundfont/tsf.h:2100:1: internal compiler error: in extract_constrain_insn, at recog.c:2210</p>
<p dir="auto">Please submit a full bug report,</p>
<p dir="auto">with preprocessed source if appropriate.</p>
<p dir="auto">See <a href="https://gcc.gnu.org/bugs/" target="_blank" rel="noopener noreferrer nofollow ugc">https://gcc.gnu.org/bugs/</a> for instructions.</p>
<p dir="auto">exit status 1</p>
<p dir="auto">Error compiling for board M5Stack-Core2.</p>
]]></description><link>https://community.m5stack.com/post/16001</link><guid isPermaLink="true">https://community.m5stack.com/post/16001</guid><dc:creator><![CDATA[jdonth]]></dc:creator><pubDate>Thu, 30 Dec 2021 17:42:09 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Tue, 21 Dec 2021 21:00:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clairlune" aria-label="Profile: clairlune">@<bdi>clairlune</bdi></a><br />
See my reply <a class="plugin-mentions-user plugin-mentions-a" href="/user/bhupiister" aria-label="Profile: bhupiister">@<bdi>bhupiister</bdi></a> (after it has been approved). Hope it solves your problem.</p>
]]></description><link>https://community.m5stack.com/post/15912</link><guid isPermaLink="true">https://community.m5stack.com/post/15912</guid><dc:creator><![CDATA[perlix]]></dc:creator><pubDate>Tue, 21 Dec 2021 21:00:53 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Tue, 21 Dec 2021 20:57:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bhupiister" aria-label="Profile: bhupiister">@<bdi>bhupiister</bdi></a><br />
I had a similar problem. You could try to remove the line 'Serial.begin(115200);' in setup(). It has already been called by M5Core2.cpp from the library. Calling it a second time makes a couple of my sketches hang.</p>
]]></description><link>https://community.m5stack.com/post/15911</link><guid isPermaLink="true">https://community.m5stack.com/post/15911</guid><dc:creator><![CDATA[perlix]]></dc:creator><pubDate>Tue, 21 Dec 2021 20:57:08 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sun, 28 Nov 2021 17:24:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homeuser33" aria-label="Profile: homeuser33">@<bdi>homeuser33</bdi></a> said in <a href="/post/13273">Updated version, working Core2 web radio player, M5Stack</a>:</p>
<blockquote></blockquote>
<p dir="auto">Hello, the code runs but it is stuck on the "Connecting" screen from the initwifi() function. I put the correct SSID and password it is still not working. Please try to help me out.</p>
]]></description><link>https://community.m5stack.com/post/15645</link><guid isPermaLink="true">https://community.m5stack.com/post/15645</guid><dc:creator><![CDATA[clairlune]]></dc:creator><pubDate>Sun, 28 Nov 2021 17:24:22 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Fri, 12 Nov 2021 07:31:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homeuser33" aria-label="Profile: homeuser33">@<bdi>homeuser33</bdi></a> I tried downloading your code and running. It compiles and load on Core2 but then the touch does not work and cannot hear any Audio, it feels like the program has halted. It does try to play something as i can hear a sound but after that it stops.</p>
]]></description><link>https://community.m5stack.com/post/15447</link><guid isPermaLink="true">https://community.m5stack.com/post/15447</guid><dc:creator><![CDATA[bhupiister]]></dc:creator><pubDate>Fri, 12 Nov 2021 07:31:35 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Mon, 29 Mar 2021 02:02:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raychmond" aria-label="Profile: raychmond">@<bdi>raychmond</bdi></a><br />
Thanks for the update,  It's been awhile sine I added the Core2 board manager so I don't remember which source I used.  If I find it I'll update here.  Thank you.</p>
]]></description><link>https://community.m5stack.com/post/13299</link><guid isPermaLink="true">https://community.m5stack.com/post/13299</guid><dc:creator><![CDATA[homeuser33]]></dc:creator><pubDate>Mon, 29 Mar 2021 02:02:04 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sun, 28 Mar 2021 22:49:51 GMT]]></title><description><![CDATA[<p dir="auto">I think it's the matter of the board selection. When I first tried homeuser33's code I used the M5Stack OEM board: M5Stack Arduino&gt;M5Stack-Core2(The PSRAM is enabled). It kept rebooting itself. I then switched to ESP32 Arduino&gt;M5Stack-Core2(The PSRAM is enabled as well), it then worked.<br />
Today, I tried different combinations. It ended up with that the only scenario that it's not working if you use M5Stack Arduino&gt;M5Stack-Core2 with PSRAM enabled. M5Stack Arduino&gt;M5Stack-Core2 with PSRAM disabled works perfectly like world101 said. But if you use ESP32 Arduino&gt;M5Stack-Core2, both enabled and disabled work. So I guess this is the matter of selecting different boards.</p>
]]></description><link>https://community.m5stack.com/post/13298</link><guid isPermaLink="true">https://community.m5stack.com/post/13298</guid><dc:creator><![CDATA[raychmond]]></dc:creator><pubDate>Sun, 28 Mar 2021 22:49:51 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sun, 28 Mar 2021 21:46:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a><br />
I'm not sure what to say about that,  PSRAM is enabled on my Linux setup and so far seems to be working.</p>
]]></description><link>https://community.m5stack.com/post/13297</link><guid isPermaLink="true">https://community.m5stack.com/post/13297</guid><dc:creator><![CDATA[homeuser33]]></dc:creator><pubDate>Sun, 28 Mar 2021 21:46:47 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sun, 28 Mar 2021 17:05:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homeuser33" aria-label="Profile: homeuser33">@<bdi>homeuser33</bdi></a></p>
<p dir="auto">Two things based on my  testing.</p>
<li>The program works with latest ESP8266Audio v1.8.1 library as well.</li>
<li>I had to disable PSRAM in the Arduino board settings to get the program to work. When enabled, Arduino would flash the program and reset, but nothing would happen after that. Here is my board setup for Arduino on my Mac.</li>
<p dir="auto"><img src="/assets/uploads/files/1616950981314-screen-shot-2021-03-28-at-1.01.24-pm-resized.png" alt="0_1616950951750_Screen Shot 2021-03-28 at 1.01.24 PM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/13294</link><guid isPermaLink="true">https://community.m5stack.com/post/13294</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sun, 28 Mar 2021 17:05:05 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sun, 28 Mar 2021 16:19:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homeuser33" aria-label="Profile: homeuser33">@<bdi>homeuser33</bdi></a></p>
<p dir="auto">👍🏻👍🏻👍🏻 Thanks!</p>
]]></description><link>https://community.m5stack.com/post/13292</link><guid isPermaLink="true">https://community.m5stack.com/post/13292</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sun, 28 Mar 2021 16:19:49 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sun, 28 Mar 2021 15:44:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a></p>
<p dir="auto">Okay, that seemed easier than I thought.<br />
Link: <a href="https://github.com/bwbguard/M5Stack-Core2-MediaPlayer" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bwbguard/M5Stack-Core2-MediaPlayer</a></p>
]]></description><link>https://community.m5stack.com/post/13290</link><guid isPermaLink="true">https://community.m5stack.com/post/13290</guid><dc:creator><![CDATA[homeuser33]]></dc:creator><pubDate>Sun, 28 Mar 2021 15:44:05 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sun, 28 Mar 2021 15:23:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/world101" aria-label="Profile: world101">@<bdi>world101</bdi></a><br />
No,  It's a good point.  Generally I have not shared much code since I'm still fairly new to the M5Stack hardware.  I was thinking this would be a one off since I found the answer for the media player.   But its a good point.  I'll check into that.<br />
Thank you.</p>
]]></description><link>https://community.m5stack.com/post/13289</link><guid isPermaLink="true">https://community.m5stack.com/post/13289</guid><dc:creator><![CDATA[homeuser33]]></dc:creator><pubDate>Sun, 28 Mar 2021 15:23:34 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sun, 28 Mar 2021 14:57:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homeuser33" aria-label="Profile: homeuser33">@<bdi>homeuser33</bdi></a></p>
<p dir="auto">Just a suggestion... Instead of posting your code and updates here, can you please upload them to Github so change management and commits are easier to track? I apologize if you already have it on Github... maybe I missed it.</p>
]]></description><link>https://community.m5stack.com/post/13287</link><guid isPermaLink="true">https://community.m5stack.com/post/13287</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sun, 28 Mar 2021 14:57:34 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sun, 28 Mar 2021 14:52:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raychmond" aria-label="Profile: raychmond">@<bdi>raychmond</bdi></a><br />
Thank you,  I've added the include now in the program,  not sure why it worked for me without it.</p>
<p dir="auto">I'll make the changes in the program listing above.  Thank you.</p>
<p dir="auto">Yes,  I like Charlie FM :  <a href="https://worldradiomap.com/us-or/play/kych_live" target="_blank" rel="noopener noreferrer nofollow ugc">https://worldradiomap.com/us-or/play/kych_live</a><br />
If you click the 'Listen with your player'  button it downloads a .PLS file that has links to their station.   I have not found many good stations with this option.</p>
<p dir="auto"><a href="https://www.radio.com/charliefm" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.radio.com/charliefm</a></p>
]]></description><link>https://community.m5stack.com/post/13286</link><guid isPermaLink="true">https://community.m5stack.com/post/13286</guid><dc:creator><![CDATA[homeuser33]]></dc:creator><pubDate>Sun, 28 Mar 2021 14:52:21 GMT</pubDate></item><item><title><![CDATA[Reply to Updated version,  working Core2 web radio player, M5Stack on Sun, 28 Mar 2021 02:22:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homeuser33" aria-label="Profile: homeuser33">@<bdi>homeuser33</bdi></a><br />
Thanks for the updates. The new version gave me compiling error because the font not found. Then I added #include "Free_Fonts.h", now it's working.<br />
I really like this web radio player, especially the stations you chose. I play this all day by my laptop.<br />
Looking forward to seeing the new updates.</p>
]]></description><link>https://community.m5stack.com/post/13279</link><guid isPermaLink="true">https://community.m5stack.com/post/13279</guid><dc:creator><![CDATA[raychmond]]></dc:creator><pubDate>Sun, 28 Mar 2021 02:22:16 GMT</pubDate></item></channel></rss>
