<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ATOM HUB AC&#x2F;DC, RS-485 VOLTAGE CONVERTER, VOLTAGE PROBLEM]]></title><description><![CDATA[<p dir="auto">I am working on a project where the switch is controlled by the M5 PIR SENSOR.<br />
When I power the ATOM from USB everything works fine, when I power it with a 12V 3A PSU thought the RS485 voltage converter the PIR begins malfunctioning (fake triggers).</p>
<p dir="auto">I checked the voltage of the two groove outputs (from the hub and from the atom lite) under USB and 12V power. As long as USB is connected, the interfaces shows a quite stable 4.98V.<br />
When the USB is unplugged, leaving only the 12V power source, the voltage drops to 3.3-3.28V, if the atom is removed it goes back to 5V<br />
I guess this is causing the PIR to misbehave, since it requires 5V.</p>
<p dir="auto">What´s wrong?<br />
According to labels on the components and to the HUB schematics, I expect 5V 2A from the DC/DC converter.</p>
<p dir="auto"><img src="/assets/uploads/files/1617022245614-1-resized.jpg" alt="0_1617022207056_1.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1617022237243-2-resized.jpg" alt="0_1617022213126_2.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1617022251558-3-resized.jpg" alt="0_1617022220086_3.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1617022264667-4-resized.jpg" alt="0_1617022224454_4.jpg" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1617022252907-img_20210329_144131-resized.jpg" alt="0_1617022236413_IMG_20210329_144131.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1617022277105-switch_schem-resized.jpg" alt="0_1617022270513_Switch_schem.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/3133/atom-hub-ac-dc-rs-485-voltage-converter-voltage-problem</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 13:47:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3133.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Mar 2021 12:51:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ATOM HUB AC&#x2F;DC, RS-485 VOLTAGE CONVERTER, VOLTAGE PROBLEM on Sat, 19 Jun 2021 07:17:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kine90" aria-label="Profile: kine90">@<bdi>kine90</bdi></a> said in <a href="/post/13314">ATOM HUB AC/DC, RS-485 VOLTAGE CONVERTER, VOLTAGE PROBLEM</a>:</p>
<p dir="auto">Based on your photo's you haven't connected the 12V to the correct pins of the RS485 connection.<br />
12V needs to be connected to the RS485's red and black pins.</p>
]]></description><link>https://community.m5stack.com/post/14145</link><guid isPermaLink="true">https://community.m5stack.com/post/14145</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 19 Jun 2021 07:17:45 GMT</pubDate></item><item><title><![CDATA[Reply to ATOM HUB AC&#x2F;DC, RS-485 VOLTAGE CONVERTER, VOLTAGE PROBLEM on Sat, 19 Jun 2021 05:23:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi it seem you are powering the 12v wrongly.</p>
<p dir="auto">Based on sticker of the HUB, red is 12v and black is gnd.</p>
<p dir="auto">Hope this helps</p>
<p dir="auto">Jason</p>
]]></description><link>https://community.m5stack.com/post/14144</link><guid isPermaLink="true">https://community.m5stack.com/post/14144</guid><dc:creator><![CDATA[JasonTay]]></dc:creator><pubDate>Sat, 19 Jun 2021 05:23:57 GMT</pubDate></item></channel></rss>
