<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PbHUB doesn&#x27;t work]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have connected a PbHUB to the i2c bus of the M5stack and the angle sensor unit connected to the PbHub.</p>
<p dir="auto">Unfortunately, with the Arduino sample code, I only get a value of 255 on all ports (Multiple ports tried)<br />
Without the unit connected to i2c, all values ​​will be 0.</p>
<p dir="auto">I have already tried two different PbHUBS and two M5Stacks, both the same result.</p>
<p dir="auto">All other connected i2c units just work fine.</p>
<p dir="auto">Could there be an error in the code for the PbHUB?</p>
]]></description><link>https://community.m5stack.com/topic/3134/pbhub-doesn-t-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:00:54 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3134.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Mar 2021 14:39:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PbHUB doesn&#x27;t work on Thu, 15 Apr 2021 23:55:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/devilstower" aria-label="Profile: devilstower">@<bdi>devilstower</bdi></a>, I am newbie. I think pbhub is only for digital/analog readings, ENV (i2c multiple data) sensor is out os scope for this I/O expander. The right one for ENV is pahub, as you confirmed. Try PIR, ANGLE  or BUTTON on pbhub, worked for me. Bye.</p>
]]></description><link>https://community.m5stack.com/post/13537</link><guid isPermaLink="true">https://community.m5stack.com/post/13537</guid><dc:creator><![CDATA[peixoto1970]]></dc:creator><pubDate>Thu, 15 Apr 2021 23:55:11 GMT</pubDate></item><item><title><![CDATA[Reply to PbHUB doesn&#x27;t work on Thu, 15 Apr 2021 23:01:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rob_d" aria-label="Profile: rob_d">@<bdi>rob_d</bdi></a> I've also had no luck with the PbHUB, even when using a single unit. Switching to a PaHUB things worked as expected.</p>
<p dir="auto">In UIFlow, if I take an ENV sensor and hook it up to a port on the PbHUB, the program just gives me an error saying the unit wasn't found (and yes, I indicated the sensor was on the hub and selected to correct port). However, take the same unit and hook it up directly, or through a PaHUB, and everything is fine. I understand the PbHUB isn't suitable for using multiple sensors of the same type, but this is happening even with just a single sensor attached to the hub.</p>
]]></description><link>https://community.m5stack.com/post/13536</link><guid isPermaLink="true">https://community.m5stack.com/post/13536</guid><dc:creator><![CDATA[Devilstower]]></dc:creator><pubDate>Thu, 15 Apr 2021 23:01:22 GMT</pubDate></item></channel></rss>
