<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Watering unit never stop]]></title><description><![CDATA[<p dir="auto">I plugged the watering unit in a Core Gray (3 buttons)<br />
The pump starts but never stop:</p>
<li>I tried with the Watering Test</li>
<li>I tried with the example of the documentation and set the pump status to 0<br />
It's impossible to stop the pump!<br />
What did I miss?<br />
Do I need a Core 2? But nothing is written about this</li>
]]></description><link>https://community.m5stack.com/topic/3142/watering-unit-never-stop</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 06:46:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3142.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Apr 2021 15:27:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Watering unit never stop on Fri, 02 Apr 2021 18:39:45 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/k33g" aria-label="Profile: k33g">@<bdi>k33g</bdi></a></p>
<p dir="auto">in the M5Stack world there are 3 different Groove ports (A - red, B - black and C - blue) for different types of units.</p>
<p dir="auto">PORT                 PIN         Note:<br />
PORT-A(Red)    G21/22  I2C<br />
PORT-B(Black) G26/36  DAC/ADC<br />
PORT-C(Blue)   G16/17  UART</p>
<p dir="auto">The Groove port built into M5Stack (Gray, Fire, Basic, etc.) is port A (red).</p>
<p dir="auto">However the watering unit needs to be connected to port B (black) for the <a href="https://github.com/m5stack/M5Stack/tree/master/examples/Unit/WATERING" target="_blank" rel="noopener noreferrer nofollow ugc">example</a> to work.</p>
<p dir="auto">Note: Groove port B (black) and port C (blue) are available on the <a href="https://m5stack-store.myshopify.com/collections/m5-base/products/battery-bottom-charging-base" target="_blank" rel="noopener noreferrer nofollow ugc">M5GO Bottom</a>.</p>
]]></description><link>https://community.m5stack.com/post/13360</link><guid isPermaLink="true">https://community.m5stack.com/post/13360</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 02 Apr 2021 18:39:45 GMT</pubDate></item></channel></rss>
