<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Set millis or nanos for the RTC]]></title><description><![CDATA[<p dir="auto">I did some searching both on the web and in the source code, and could not find a way to set the millis or nanos of the RTC clock. Is there a way to do this currently? My end goal is to sync the RTC with a GPS via a serial connection, so that the clocks on separate M5StickC's will match up accurately.</p>
]]></description><link>https://community.m5stack.com/topic/3145/set-millis-or-nanos-for-the-rtc</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 07:08:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3145.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 03 Apr 2021 17:18:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Set millis or nanos for the RTC on Sun, 04 Apr 2021 09:45:07 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/dan95363" aria-label="Profile: Dan95363">@<bdi>Dan95363</bdi></a></p>
<p dir="auto">Have you had a look at the BM8563 datasheet? I don't think the BM8563 supports millis or nanos. I only see a register for seconds.</p>
]]></description><link>https://community.m5stack.com/post/13370</link><guid isPermaLink="true">https://community.m5stack.com/post/13370</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 04 Apr 2021 09:45:07 GMT</pubDate></item></channel></rss>
