<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Get NTP timestamp with COM.LTE module does not work?]]></title><description><![CDATA[<p dir="auto">Hi,<br />
using a M5S Core1 with COM.LTE for mobile data connectivity which an MQTT client, implemented with UIFlow, uses pretty well to send data. Now I need to get a timestamp to be put into MQTT flow.<br />
I thought to use NTP blocks library but apparently it does not work when underlying connection is mobile while it works only with WiFi.<br />
Any tip to overcome such a limitation?</p>
]]></description><link>https://community.m5stack.com/topic/3164/get-ntp-timestamp-with-com-lte-module-does-not-work</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:22:13 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3164.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Apr 2021 06:07:48 GMT</pubDate><ttl>60</ttl></channel></rss>
