<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mini Infrared Emitter &amp; Receiver Unit]]></title><description><![CDATA[<p dir="auto">I have recently bought the core and atom to test the Mini Infrared Emitter &amp; Receiver Unit. The stock example UI Flow allows me to only get status of IR receiver , while i would like to read from a remote and emulate the same signal.<br />
Is there a way i can read the input signal and store and emulate the same out ?.<br />
Like using the existing block and modifying the micropython code, or making a new block with block maker and importing external libraries, or using an arduino C and cross compiling the same to a .mpy file and using the same .<br />
Any ideas , inputs , examples welcome  . really stuck with this .Thanks in advance</p>
]]></description><link>https://community.m5stack.com/topic/3169/mini-infrared-emitter-receiver-unit</link><generator>RSS for Node</generator><lastBuildDate>Wed, 06 May 2026 15:17:57 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3169.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Apr 2021 05:24:50 GMT</pubDate><ttl>60</ttl></channel></rss>
