<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Deep sleep high current on Atom]]></title><description><![CDATA[<p dir="auto">I'm testing deep sleep current for an Atom project. Atom starts, current is about 50mA. In deep sleep current drops to less than 1mA, which is what I expect. Atom awakes after 30 seconds to do its regular job, then goes to deep sleep again. However, this time (and all subsequent times) deep sleep current is about 11mA. When I press the reset button immediately after power on, the first deep sleep is also 11mA. I can also see a difference in the active current in the order of 11mA. There are no units connected. Whatever I do, disable Serial, I2C, Display, isolate GPIOs or not, there is no effect.<br />
Unfortunately M5Stack doesn't provide schematics for the Atom, just a block diagram which misses out a lot of details.<br />
Any ideas? Should I remove the RGB Led or the IR transmitter. My best guess is it is the FTDI chip coming out of sleep mode due to some fluctuation on the TX/RX lines. But without schematics I cannot do much.  What I found on FTDI is something like 8-15mA, depending on the chip type. The only one in SSOP20 package is FT231X. Any help welcome. Below 1mA is good, but 11mA deep sleep current is a nightmare. There are many questions on the deep sleep power issue and I'd be very glad if M5 could do something to improve this ...</p>
]]></description><link>https://community.m5stack.com/topic/3188/deep-sleep-high-current-on-atom</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 23:34:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3188.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Apr 2021 18:50:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Deep sleep high current on Atom on Sat, 17 Apr 2021 12:06:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Tried both. 3.3V has a bit higher current. Strange, if there's just an LDO (guessing - no schematics!).<br />
Also removed IR and RGB LEDs. Tried with Arduino and Espressif IDF deep-sleep example. No success. NodeMCU with Wroom32 is kind of OK (1.6mA), by the way. But mechanically too large ...</p>
]]></description><link>https://community.m5stack.com/post/13552</link><guid isPermaLink="true">https://community.m5stack.com/post/13552</guid><dc:creator><![CDATA[oklab-ka]]></dc:creator><pubDate>Sat, 17 Apr 2021 12:06:52 GMT</pubDate></item><item><title><![CDATA[Reply to Deep sleep high current on Atom on Wed, 14 Apr 2021 07:15:19 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/oklab-ka" aria-label="Profile: oklab-ka">@<bdi>oklab-ka</bdi></a></p>
<p dir="auto">just curious, are you powering M5Atom from 5 V (e.g. USB) or 3.3 V?</p>
]]></description><link>https://community.m5stack.com/post/13522</link><guid isPermaLink="true">https://community.m5stack.com/post/13522</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 14 Apr 2021 07:15:19 GMT</pubDate></item></channel></rss>
