<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UnitV OV2640 &#x2F; MaixPy does not work with the current Tutorial !]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I recently buy the UnitV K210 OV2640 module for my robotics applications.<br />
I follow the tutorial to make it work with the MaixPy IDE (test with V0.2.5 and V0.2.4) so I burned the camera flash with the "M5StickV_Firmware_v5.1.2.kfpkg" firmware.</p>
<p dir="auto">I connect the camera to my computer with Maixpy running : the camera feed don't show up and when I run the test sample program (without the lcd part) I can read in the terminal that the camera is not recognized as a OV2640 but as a new OV7740 which make make all vision program unusable due to driver incompatibility...(I test color and QR code code)</p>
<p dir="auto"><img src="/assets/uploads/files/1618341590114-capture.png" alt="0_1618341589238_Capture.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Do you have any Idea ?<br />
Is it possible to have a compatible firmware ?<br />
Or is it the Maixpy version that is incompatible ?</p>
<p dir="auto">Best regards,</p>
<p dir="auto">Neurotronics67.</p>
]]></description><link>https://community.m5stack.com/topic/3192/unitv-ov2640-maixpy-does-not-work-with-the-current-tutorial</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 19:42:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3192.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Apr 2021 19:21:23 GMT</pubDate><ttl>60</ttl></channel></rss>
