<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Upload time out]]></title><description><![CDATA[<p dir="auto">Hi, now I am try to upload  in windows system but failed several times.<br />
The messege is as following :<br />
<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v2.1<br />
Connecting........<em><strong><strong>.....</strong></strong></em>.....<em><strong><strong>.....</strong></strong></em>.....<em><strong><strong>.....</strong></strong></em>.....<em><strong><strong>.....</strong></strong></em>.....<em><strong><strong>.....</strong></strong></em></p>
<p dir="auto">A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header<br />
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header</p>
<p dir="auto">I felt the M5 was rebooting  during upload.<br />
What's going on it?<br />
Please let me know.</p>
]]></description><link>https://community.m5stack.com/topic/32/upload-time-out</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:20:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/32.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Dec 2017 02:41:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Upload time out on Wed, 03 Jan 2018 17:26:00 GMT]]></title><description><![CDATA[<p dir="auto">Maybe also in your case also <a href="http://forum.m5stack.com/topic/55/simple-fix-when-upload-fails" target="_blank" rel="noopener noreferrer nofollow ugc">this workaround</a> helps during using VMware.</p>
]]></description><link>https://community.m5stack.com/post/135</link><guid isPermaLink="true">https://community.m5stack.com/post/135</guid><dc:creator><![CDATA[SR]]></dc:creator><pubDate>Wed, 03 Jan 2018 17:26:00 GMT</pubDate></item><item><title><![CDATA[Reply to Upload time out on Wed, 03 Jan 2018 16:01:17 GMT]]></title><description><![CDATA[<p dir="auto">OK, now I totally understand where the blocking is:</p>
<p dir="auto">"VWMare"</p>
<p dir="auto">I use vmware images for all dev stuff,  it's more neat when I work between different computers. however, I did not realise that vmware add an intermedia traitment between usb device and guest OS, I thought it was connected directly.</p>
<p dir="auto">So solution is simple, I have to compile my codes under Windows (win10 x64) or Linux (Ubuntu 16.0.4), both work well, but never under vmware.</p>
]]></description><link>https://community.m5stack.com/post/134</link><guid isPermaLink="true">https://community.m5stack.com/post/134</guid><dc:creator><![CDATA[zuobiao]]></dc:creator><pubDate>Wed, 03 Jan 2018 16:01:17 GMT</pubDate></item><item><title><![CDATA[Reply to Upload time out on Fri, 15 Dec 2017 08:48:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dimi" aria-label="Profile: dimi">@<bdi>dimi</bdi></a><br />
Thanks for Dimi, I did not read the Lesson 1 before.</p>
<p dir="auto">I just follow all steps for the lesson, under windows 7, with driver 5.40.24, using Arduino1.8.5 downloaded directly from <a href="http://m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">m5stack.com</a>, I can total compil the example code "hello world", but always rejected during flashing.</p>
<p dir="auto">Is there any possibility that my M5Stack has material default?</p>
]]></description><link>https://community.m5stack.com/post/101</link><guid isPermaLink="true">https://community.m5stack.com/post/101</guid><dc:creator><![CDATA[zuobiao]]></dc:creator><pubDate>Fri, 15 Dec 2017 08:48:20 GMT</pubDate></item><item><title><![CDATA[Reply to Upload time out on Thu, 14 Dec 2017 06:04:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zuobiao" aria-label="Profile: zuobiao">@<bdi>zuobiao</bdi></a> please read the Lesson 1. Everything is written: <a href="http://forum.m5stack.com/topic/40/lesson-1-the-beginning-of-the-work" target="_blank" rel="noopener noreferrer nofollow ugc">http://forum.m5stack.com/topic/40/lesson-1-the-beginning-of-the-work</a></p>
]]></description><link>https://community.m5stack.com/post/97</link><guid isPermaLink="true">https://community.m5stack.com/post/97</guid><dc:creator><![CDATA[Dimi]]></dc:creator><pubDate>Thu, 14 Dec 2017 06:04:22 GMT</pubDate></item><item><title><![CDATA[Reply to Upload time out on Wed, 13 Dec 2017 11:09:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dimi" aria-label="Profile: dimi">@<bdi>dimi</bdi></a> 在 <a href="/post/93">Upload time out</a> 中说：</p>
<p dir="auto">5.40.24.</p>
<p dir="auto">Hi dimi, thank you for your reply, could you please tell me where to get the driver version 5.40.24? I can not find it in the silabs homepage.</p>
]]></description><link>https://community.m5stack.com/post/95</link><guid isPermaLink="true">https://community.m5stack.com/post/95</guid><dc:creator><![CDATA[zuobiao]]></dc:creator><pubDate>Wed, 13 Dec 2017 11:09:44 GMT</pubDate></item><item><title><![CDATA[Reply to Upload time out on Wed, 13 Dec 2017 09:28:06 GMT]]></title><description><![CDATA[<p dir="auto">Если у Вас Win7, то установите драйвер версии 5.40.24. И проверьте версию через диспетчер устройств. Так же попробуйте во время процесса нажать кнопку питания на M5Stack.</p>
<p dir="auto">If You have Win7, then install the driver version 5.40.24. And check the version through the device Manager. Also try during the process, press the power button on M5Stack.</p>
]]></description><link>https://community.m5stack.com/post/93</link><guid isPermaLink="true">https://community.m5stack.com/post/93</guid><dc:creator><![CDATA[Dimi]]></dc:creator><pubDate>Wed, 13 Dec 2017 09:28:06 GMT</pubDate></item><item><title><![CDATA[Reply to Upload time out on Tue, 12 Dec 2017 18:18:31 GMT]]></title><description><![CDATA[<p dir="auto">I have the same problem.<br />
a brand new M5STACK core, with Arduino1.8.5 + library M5Stack from github + driver Linux_3.x.x_4.x.x_VCP from <a href="http://silabs.com" target="_blank" rel="noopener noreferrer nofollow ugc">silabs.com</a>, I got error message:</p>
<p dir="auto">Archiving built core (caching) in: /tmp/arduino_cache_375208/core/core_espressif_esp32_esp32_FlashMode_qio,FlashFreq_80,FlashSize_4M,UploadSpeed_921600,DebugLevel_none_41c73171d0dd7eab7864b998a89c78d5.a<br />
Sketch uses 135724 bytes (10%) of program storage space. Maximum is 1310720 bytes.<br />
Global variables use 10592 bytes (3%) of dynamic memory, leaving 284320 bytes for local variables. Maximum is 294912 bytes.<br />
<p dir="auto">I'm total lost.</p>
<p dir="auto">Dev under Debian9 x64.</p>
]]></description><link>https://community.m5stack.com/post/89</link><guid isPermaLink="true">https://community.m5stack.com/post/89</guid><dc:creator><![CDATA[zuobiao]]></dc:creator><pubDate>Tue, 12 Dec 2017 18:18:31 GMT</pubDate></item></channel></rss>
