<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[GPS AT6558 Core Gray Confusion]]></title><description><![CDATA[<p dir="auto">Hi all, this is my first post here as I haven't been able to find this info anywhere else.  I recently purchase a Core2 Gray for use with a GPS/IMU project.  I also purchased the AT6558 GPS unit because it appeared to just plug right in(or so I thought).</p>
<p dir="auto">Documentation on the GPS shows a pinmap with GROVE C on the M5Core which is RX(16), TX(17), 5V and GND.  It has that lining up with TX,RX,5v, GND on the GPS. <a href="https://docs.m5stack.com/#/en/unit/gps" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/unit/gps</a></p>
<p dir="auto">So my GROVE port is red so A? The documentation when I bought this said "You can plug it into the Grove port C on an M5 Core.  I guess I am/was confused as to whether or not this should work.  Specs on the M5Core Gray list the "Port" as TypeC which says I2C+I/O+UART.  I think the Type C threw me off as it was somehow configurable</p>
<p dir="auto">So can someone clear up this confusion for me as to what M5PORT EXPLAIN is on the site showing</p>
<li>
<p dir="auto">Port-A(Red) G21/22 I2C</p>
</li>
<li>
<p dir="auto">Port-B(Black) G26/36 DAC/ADC</p>
</li>
<li>
<p dir="auto">Port-C(Blue) G16/17 UART</p>
</li>
<p dir="auto">So out of all that :)</p>
<li>Am I correct to assume that my Core Grey GROOVE connector is fixed I2C?</li>
<li>Can I communicate with the GPS unit via I2C?  I know there are some gps modules with special firmware that makes it possible but don't know about this GPS module.  I was thinking maybe i just missed a setting.</li>
<p dir="auto">I am thinking at this point my only option to use this GPS Unit is to hook it up to 16/17 UART on the M5 or go back to one of my UBLOX modules.</p>
<p dir="auto">Thanks in advance!<br />
Matt</p>
]]></description><link>https://community.m5stack.com/topic/3212/gps-at6558-core-gray-confusion</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 01:32:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3212.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Apr 2021 19:27:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to GPS AT6558 Core Gray Confusion on Thu, 29 Apr 2021 22:45:28 GMT]]></title><description><![CDATA[<p dir="auto">I mistaking posted this in core2, but wanted to chime back in as I have it working.  Still not sure how to get the right port with my gray but if someone finds this I wanted to link the solution.</p>
<p dir="auto"><a href="https://127.0.0.1:6060/topic/3217/hardwareserial-ss-2-uart-connection-on-16-17-for-a-gps-antenna" target="_blank" rel="noopener noreferrer nofollow ugc">https://127.0.0.1:6060/topic/3217/hardwareserial-ss-2-uart-connection-on-16-17-for-a-gps-antenna</a></p>
]]></description><link>https://community.m5stack.com/post/13670</link><guid isPermaLink="true">https://community.m5stack.com/post/13670</guid><dc:creator><![CDATA[Shift1313]]></dc:creator><pubDate>Thu, 29 Apr 2021 22:45:28 GMT</pubDate></item><item><title><![CDATA[Reply to GPS AT6558 Core Gray Confusion on Thu, 22 Apr 2021 13:24:19 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the reply ajb2k3!</p>
<p dir="auto">The gray i have is standard, no additional base/modules.  It had everything i needed except GPS which is why I got the Unit before noticing the GROOVE connector wasn't UART.  16/17 are clearly marked on the base I was just hoping for a clean/durable connection between the GPS Unit and the Core that the dupont connectors wouldn't provide.</p>
<p dir="auto">Ill give the unit a test jumpering it to 16/17/5v/gnd on the dupont connectors.</p>
]]></description><link>https://community.m5stack.com/post/13592</link><guid isPermaLink="true">https://community.m5stack.com/post/13592</guid><dc:creator><![CDATA[Shift1313]]></dc:creator><pubDate>Thu, 22 Apr 2021 13:24:19 GMT</pubDate></item><item><title><![CDATA[Reply to GPS AT6558 Core Gray Confusion on Thu, 22 Apr 2021 05:11:21 GMT]]></title><description><![CDATA[<p dir="auto">The Red grove port is for I2C but can be used for some other uses.<br />
The GPS modules uses UART, the pins for this can be found on the mini bus<br />
What base do you have connected to the gray as the UART pins tx/rx are marked on the base with male and female dupont connectors.</p>
]]></description><link>https://community.m5stack.com/post/13588</link><guid isPermaLink="true">https://community.m5stack.com/post/13588</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 22 Apr 2021 05:11:21 GMT</pubDate></item></channel></rss>
