<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Will the GRBL 13.2 module work with Core2?]]></title><description><![CDATA[<p dir="auto">Will it?  There really needs to be clear documentation about this kind of stuff.  I want to support the platform but there seems to be no way to tell what modules work where, and that's kind of important since it's one of the main draws (if not THE main draw) of the platform.</p>
]]></description><link>https://community.m5stack.com/topic/3238/will-the-grbl-13-2-module-work-with-core2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 16:17:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3238.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Apr 2021 22:23:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Will the GRBL 13.2 module work with Core2? on Mon, 07 Feb 2022 14:58:10 GMT]]></title><description><![CDATA[<p dir="auto">I received my Core2 and GRBL 13.2 module and it works due to <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> 's hints:<br />
<a href="https://community.m5stack.com/post/16551">https://community.m5stack.com/post/16551</a></p>
]]></description><link>https://community.m5stack.com/post/16549</link><guid isPermaLink="true">https://community.m5stack.com/post/16549</guid><dc:creator><![CDATA[em]]></dc:creator><pubDate>Mon, 07 Feb 2022 14:58:10 GMT</pubDate></item><item><title><![CDATA[Reply to Will the GRBL 13.2 module work with Core2? on Fri, 11 Jun 2021 01:59:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/makermatrix" aria-label="Profile: makermatrix">@<bdi>makermatrix</bdi></a></p>
<p dir="auto">Did you figure it out? I just got the GRBL13.2 module and looking for info on how to use it.</p>
]]></description><link>https://community.m5stack.com/post/14079</link><guid isPermaLink="true">https://community.m5stack.com/post/14079</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Fri, 11 Jun 2021 01:59:25 GMT</pubDate></item><item><title><![CDATA[Reply to Will the GRBL 13.2 module work with Core2? on Wed, 28 Apr 2021 15:05:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thank you for the help, I might try it.</p>
]]></description><link>https://community.m5stack.com/post/13654</link><guid isPermaLink="true">https://community.m5stack.com/post/13654</guid><dc:creator><![CDATA[MakerMatrix]]></dc:creator><pubDate>Wed, 28 Apr 2021 15:05:17 GMT</pubDate></item><item><title><![CDATA[Reply to Will the GRBL 13.2 module work with Core2? on Wed, 28 Apr 2021 08:39:22 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/makermatrix" aria-label="Profile: MakerMatrix">@<bdi>MakerMatrix</bdi></a></p>
<p dir="auto">I don't have that particular module, but checking the schematic I think the only change you'd need to make it work with M5Core2 in software is to use GPIO19 (instead of GPIO13) for MCU RX.</p>
<p dir="auto">That said, I don't see MCU RX being used in the provided example for M5Stack, so you might get away with only adapting the M5Stack code example to M5Core2.</p>
<p dir="auto">I made a <a href="https://gwendesign.ch/kb/m5stack/m5core2/#m5core2-bus-and-gpios-compared-to-m5stack" target="_blank" rel="noopener noreferrer nofollow ugc">GPIO comparison sheet</a> a while ago, which might help you.</p>
]]></description><link>https://community.m5stack.com/post/13644</link><guid isPermaLink="true">https://community.m5stack.com/post/13644</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 28 Apr 2021 08:39:22 GMT</pubDate></item></channel></rss>
