<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RTC not working in M5StickCPlus]]></title><description><![CDATA[<p dir="auto">It seems not possible to use the RTC component in my M5StickC Plus.<br />
I'm able to set the time (setTime) but the getTime returns always the same value.<br />
I tested many examples with the same results.<br />
Someone had the same experience ?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/3247/rtc-not-working-in-m5stickcplus</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 06:20:47 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3247.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 01 May 2021 15:43:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RTC not working in M5StickCPlus on Sun, 02 May 2021 08:49:07 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/lunard" aria-label="Profile: lunard">@<bdi>lunard</bdi></a></p>
<p dir="auto">I assume you've tried this <a href="https://github.com/m5stack/M5StickC-Plus/blob/master/examples/Basics/RTC/RTC.ino" target="_blank" rel="noopener noreferrer nofollow ugc">example</a> as well?</p>
<p dir="auto">This example should start of at the time (18:56:10) and date (3/22/2019) set in <code>setup()</code> and then advance automatically. If the clock is stuck at that time and date, then I'd say probably something's wrong with the RTC in your M5StickCPlus.</p>
]]></description><link>https://community.m5stack.com/post/13693</link><guid isPermaLink="true">https://community.m5stack.com/post/13693</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 02 May 2021 08:49:07 GMT</pubDate></item></channel></rss>
