<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Thermal unit not selectable in UIFlow]]></title><description><![CDATA[<p dir="auto">I would like to use the Thermal Unit in UIFlow (1.7.6) but in the unit selection dialog is always disabled. Take a look at the following picture.</p>
<p dir="auto"><img src="/assets/uploads/files/1620303393695-46739dcc-aeb9-4de1-9cc8-a4513907bba4-image.png" alt="0_1620303387343_46739dcc-aeb9-4de1-9cc8-a4513907bba4-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I tried with a StickC, StickC Plus and a Core2 but UIFlow doesn't let me add the Thermal unit.</p>
]]></description><link>https://community.m5stack.com/topic/3260/thermal-unit-not-selectable-in-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:09:23 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3260.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 May 2021 12:18:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Thermal unit not selectable in UIFlow on Wed, 25 Aug 2021 13:49:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dario" aria-label="Profile: dario">@<bdi>dario</bdi></a> I had the same issue, using UiFlow Beta as a version I see UiFlow 1.8.2 and for both Core2 as well as Fire I can see and add them (the THERMAL unit).<br />
Only issue I personally now have is that I have a pretty unstable connection from  the Fire or Core2 to the web IDE so I can't really apply the 1.8.2 blockly code. And the Desktop IDE at the moment is stuck at 1.7.5 that can't handle the files I save using version 1.8.2.</p>
<p dir="auto">Maybe for you with a stable UiFlow internet connection you can use version 1.8.2 to test and deploy your Thermal code.<br />
Make sure to ofcourse burn 1.8.2 to your device also.</p>
]]></description><link>https://community.m5stack.com/post/14727</link><guid isPermaLink="true">https://community.m5stack.com/post/14727</guid><dc:creator><![CDATA[capacious]]></dc:creator><pubDate>Wed, 25 Aug 2021 13:49:08 GMT</pubDate></item></channel></rss>
