<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Fire core + Plus + M5GO base = psram fails on boot]]></title><description><![CDATA[<p dir="auto">If I stack core+base or core+plus works good. If I stack all of the three it fails to boot</p>
<pre><code>Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:4
load:0x3fff0034,len:5652
load:0x40078000,len:13136
load:0x40080400,len:4356
entry 0x400806b0
E (1085) psram: PSRAM ID read error: 0x3141ba1a
E (1085) spiram: SPI RAM enabled but initialization failed. Bailing out.
E (1086) spiram: SPI RAM not initialized
Re-enable cpu cache.
abort() was called at PC 0x400f4dbe on core 0
Backtrace:0x40095ec5:0x3ffe3b60 0x400964b5:0x3ffe3b80 0x4009a6a9:0x3ffe3ba0 0x400f4dbe:0x3ffe3c10 0x400f4e0f:0x3ffe3c30 0x400829ee:0x3ffe3c50 0x400821d3:0x3ffe3c70 0x40078fd0:0x3ffe3c90 |&lt;-CORRUPTED
ELF file SHA256: b95ed270e1e6b8a7
Rebooting...
<p dir="auto">The same happens using plain esp-idf, arduino or micropython. I tried many settings (DIO-QIO... changing mhz... and so on) without any result.</p>
<p dir="auto">What can I do to make it works using core+plus+base ?</p>
]]></description><link>https://community.m5stack.com/topic/3270/m5stack-fire-core-plus-m5go-base-psram-fails-on-boot</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 08:42:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3270.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 08 May 2021 08:42:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Fire core + Plus + M5GO base = psram fails on boot on Fri, 21 May 2021 09:46:04 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/anichang" aria-label="Profile: anichang">@<bdi>anichang</bdi></a></p>
<p dir="auto">just wondering - maybe the issue isn't specific to PSRAM but with the power supply? I'd try a different power supply and/or shorter USB cable.</p>
]]></description><link>https://community.m5stack.com/post/13832</link><guid isPermaLink="true">https://community.m5stack.com/post/13832</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 21 May 2021 09:46:04 GMT</pubDate></item></channel></rss>
