<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CORE2, LAN Module W5500 with POE and RS-485]]></title><description><![CDATA[<p dir="auto">Hi,<br />
The RS-485 board of the LAN Module W5500 with POE works fine only<br />
if the PORT.A.I2C of the CORE2 is not used. If the external I2C port<br />
is in use the RS-485 communication looses the RX signal, because<br />
of the G33 asignation for both purposes, RX and PA_SCL.<br />
Somebody knows how to fix this?<br />
Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/3283/core2-lan-module-w5500-with-poe-and-rs-485</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 10:23:54 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3283.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 May 2021 22:26:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CORE2, LAN Module W5500 with POE and RS-485 on Fri, 21 May 2021 09:21:43 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/hbenkel" aria-label="Profile: hbenkel">@<bdi>hbenkel</bdi></a></p>
<p dir="auto">you are welcome. I am glad to hear you got it working to your liking.</p>
]]></description><link>https://community.m5stack.com/post/13830</link><guid isPermaLink="true">https://community.m5stack.com/post/13830</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 21 May 2021 09:21:43 GMT</pubDate></item><item><title><![CDATA[Reply to CORE2, LAN Module W5500 with POE and RS-485 on Mon, 17 May 2021 21:08:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thanks Felix for the reply. I wired the pin 27 for RX and now both RS-485 and I2C works fine.<br />
Regards</p>
]]></description><link>https://community.m5stack.com/post/13809</link><guid isPermaLink="true">https://community.m5stack.com/post/13809</guid><dc:creator><![CDATA[hbenkel]]></dc:creator><pubDate>Mon, 17 May 2021 21:08:11 GMT</pubDate></item><item><title><![CDATA[Reply to CORE2, LAN Module W5500 with POE and RS-485 on Sun, 16 May 2021 07:34:19 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/hbenkel" aria-label="Profile: hbenkel">@<bdi>hbenkel</bdi></a></p>
<p dir="auto">the only way I see is to rewire RX to an unused GPIO. Maybe this <a href="https://www.gwendesign.ch/kb/m5stack/m5core2/" target="_blank" rel="noopener noreferrer nofollow ugc">GPIO overview</a> I've put together a while back will help you.</p>
]]></description><link>https://community.m5stack.com/post/13797</link><guid isPermaLink="true">https://community.m5stack.com/post/13797</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 16 May 2021 07:34:19 GMT</pubDate></item></channel></rss>
