<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Extending M5StickC persistent memory (SD card, soldered SRAM?)]]></title><description><![CDATA[<p dir="auto">Hey, I'm thinking about using an M5StickC and I've decided that I need to extend it with an external physical persistent memory (sending data over WiFi won't do). Initially I was planning to use a Proto Hat with an SD card reader mounted, but I've found <a href="https://forum.m5stack.com/topic/1002/how-to-connect-sd-card-to-m5stickc" target="_blank" rel="noopener noreferrer nofollow ugc">this</a> topic saying that the M5StickC does not support SD cards. If that's the case, what are the other resonable options of extending M5Stick's persistent memory (I'm a newbie in the microcontrollers, but I'm eager to learn!).</p>
]]></description><link>https://community.m5stack.com/topic/3284/extending-m5stickc-persistent-memory-sd-card-soldered-sram</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 15:05:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3284.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 May 2021 09:08:54 GMT</pubDate><ttl>60</ttl></channel></rss>
